and RTEMS configuration.
<rdasilva@connecttel.com>.
future.
cd <rtems-source-tree>
preparations for automake.
* aclocal/rtems-top.m4:
on BSPs that install there own tools.
tested that the same file could not be created twice.
description follows:
Description:
config.h.ins)
acpolish
configure scripts
Remarks:
[$(prefix)].
this week until now.
It consists of 3 parts:
1. a patch
2. a perl script (acpolish)
plural).
configure scripts etc.
added by acpolish.
To apply this:
./rtems-polish.sh
Later:
cvs add contrib
cvs add contrib/acpolish
cvs commit
are:
I have a few patches for the efi332 bsp. If you let me know when you
expect the next snapshot release, I will try to have them to you
before then. Also, the malloctest has some problems that I would think
would prevent it from running on almost any platform. I have enclose
patches below to fix (1) Task_id and Task_name dimensioning, (2) end
of test message, (3) the amount of memory malloc'ed, and (4) retry on
unsuccessful (out of memory) molloc's.
that is part of the addition of POSIX timers.
that are part of the addition of POSIX timers.
blocking protocol is used.
Updated scn files to match present expected test output.
Renamed all directories to start with psx.
test suite designator. In English, we now support psxfile in addition
to psx11.
PROBLEMS
can/will be fixed.
it work.
ports.
