* | Added test cases: | Joel Sherrill | 1995-08-02 | 1 | -2/+71 |
| | | | | | | + some from Andy Bray (andy@i-cubed.demon.co.uk) which do not include task start up cost. + cases for interrupt disable, enable, and flash | ||||
* | fixed path problem for POSIX | Joel Sherrill | 1995-07-31 | 1 | -2/+2 |
* | after testing go32 and cvme961 | Joel Sherrill | 1995-07-21 | 1 | -6/+6 |
* | committing for rtems-3.2.01 snapshot | Joel Sherrill | 1995-07-18 | 2 | -3/+3 |
* | Ada95, gnat, go32 | Joel Sherrill | 1995-07-12 | 2 | -3/+3 |
* | added calls to _Thread_Disable_dispatch to match requirements | Joel Sherrill | 1995-06-05 | 1 | -3/+13 |
| | | | | for invocation of _Thread_Handler | ||||
* | conditional added for the hppa gr27 | Joel Sherrill | 1995-06-05 | 1 | -0/+2 |
* | Corrected minor number for "Null" device driver | Joel Sherrill | 1995-05-31 | 1 | -1/+1 |
* | cpu/*types.h added and successfully compiled. | Joel Sherrill | 1995-05-30 | 2 | -2/+8 |
| | | | | IDLE task priority changed from 0 to 255 during initialization. | ||||
* | Fully tested on all in-house targets | Joel Sherrill | 1995-05-24 | 6 | -15/+7 |
* | Initial revision | Joel Sherrill | 1995-05-11 | 445 | -0/+31857 |
