path: root/c/src/tests (follow)
* 2001-06-14 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-06-142-3/+5
| | | | | * cdtest/system.h: Removed configure of POSIX mutexes since there do not appear to be any used in this test.
* 2001-05-25 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-05-258-1/+211
| | | | | | | | * Added once version of psxchroot01 test for user review. * psxchroot01: New directory. * psxchroot01/Makefile.am, psxchroot01/main.c, psxchroot01/test.c, psxchroot01/psxchroot01.scn, psxchroot01/.cvsignore: New files. * configure.in, Makefile.am: Modified to reflect above.
* 2001-05-10 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-05-112-9/+5
| | | | | * configure.in: Remove RTEMS_PROG_CC_FOR_TARGET, RTEMS_PROG_CXX_FOR_TARGET, RTEMS_CANONICALIZE_TOOLS.
* 2001-05-10 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-05-1018-9/+45
| | | | * configure.in: Use RTEMS_PROG_CC_FOR_TARGET([-ansi -fasm]).
* 2001-04-24 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-04-243-0/+56
| | | | | | | * psxfile01/test.c, psxfile01/psxfile01.scn : Added test case for open, write, reopen, append twice from Andrew Bythell <abythell@nortelnetworks.com> that tripped an initialization problem in the IMFS.
* 2001-04-20 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-04-202-0/+7
| | | | | * sp298/sp28.scn: Minor adjustment so test output matches the screen file.
* 2001-04-20 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-04-2012-309/+306
| | | | | | | | * psx04/init.c, psx04/psx04.scn, psx07/init.c, psx07/psx07.scn, psxfile01/psxfile01.scn, psxmsgq01/psxmsgq01.scn, psxreaddir/test.c, psxstat/psxstat.scn, psxstat/test.c, psxtime/psxtime.scn, psxtimer/psxtimer.scn: Various adjustments so test output matches screens more reliably.
* 2001-04-20 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-04-205-6/+12
| | | | | | * itronmbf01/itronmbf01.scn, itronmbox01/init.c, itronsem01/itronsem01.scn, itrontime01/init.c: Various adjustments so test output matches screens more reliably.
* 2001-02-07 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-02-122-1/+5
| | | | * spsize/size.c: Use #if !defined(RTEMS_UNIX).
* 2001-01-26 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-01-2614-350/+11
| | | | | | | | | * configure.in: Remove stubdr, wrapup, AC_INIT(include). * Makefile.am: Remove stubdr, wrapup. * stubdr/Makefile.am, stubdr/open.c, stubdr/close.c, stubdr/init.c, stubdr/stubdrv.h, stubdr/cntrl.c, stubdr/.cvsignore, stubdr/read.c, stubdr/write.c, wrapup/Makefile.am, wrapup/.cvsignore, stubdr/, wrapup/: Remove.
* 2001-01-26 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-01-262-1/+5
| | | | * tm20/Makefile.am: Remove stubdir.rel
* 2001-01-26 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-01-262-2/+4
| | | | * sp21/Makefile.am: Remove libtest.
* 2001-01-25 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-01-252-5/+7
| | | | * psx01/psx01.scn: Corrected to reflect clock_getres() now working.
* 2000-11-17 Jennifer Averett <jennifer@OARcorp.com>Jennifer Averett2000-11-201-0/+14
| | | | | | | | | | | | | | * psxstat/test.c, psxstat/psxstat.scn: Forced inode numbers to remain consistant across platforms and bsps by forcing a mount point in front of all paths. 2000-11-17 Jennifer Averret <jennifer@OARcorp.com> * psxmount/test.c, psxmount/psxmount.scn: Improve output to report expected error condition in one case. * psxreaddir/test.c, psxreaddir.scn: Added test cases to exercise readdir() of root of mounted filesystem. Also corrected the screen file for some mistakes noticed in this effort.
* 2000-11-17 Jennifer Averret <jennifer@OARcorp.com>Jennifer Averett2000-11-202-17/+16
* 2000-11-20 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-11-202-0/+6
| | | | * itrontask01/system.h: Configure enough stack memory.
* 2000-11-17 Jennifer Averret <jennifer@OARcorp.com>Jennifer Averett2000-11-172-290/+267
* 2000-11-17 Jennifer Averret <jennifer@OARcorp.com>Jennifer Averett2000-11-174-81/+143
* 2000-11-13 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-11-153-2/+6
| | | | * psxmount/psxmount.scn, psxmount/test.c: Correct spelling.
* 2000-11-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-11-0924-12/+60
* 2000-11-02 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-11-022-1/+5
| | | | * stubdr/Makefile.am: Replace leaf.cfg w/ automake/lib.am.
* 2000-11-02 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-11-0224-12/+60
* 2000-11-01 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-11-012-1/+7
| | | | | | * malloctest/task1.c: assoc.h, error.h, libio_.h, libio.h, and libcsupport.h moved from libc to lib/include/rtems and now must be referenced as <rtems/XXX.h>.
* 2000-10-30 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-10-312-1/+9
| | | | | | | | * POSIX include files merged into newlib. This resulted in some definitions moving to other files and thus some secondary effects in RTEMS source code. * paranoia/paranoia.c: Commented out incorrect and conflicting prototype of read().
* 2000-10-26 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-10-276-3/+18
* 2000-10-26 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-10-273-2/+8
| | | | | | * Makefile.am: ACLOCAL_AMFLAGS= -I $(RTEMS_TOPdir)/macros. Switch to GNU canonicalization. * itrontests.am: Remove DEFS.
| | | | | | * Makefile.am: ACLOCAL_AMFLAGS= -I $(RTEMS_TOPdir)/macros. Switch to GNU canonicalization. * libtests.am: Remove DEFS.
| | | | | | * Makefile.am: ACLOCAL_AMFLAGS= -I $(RTEMS_TOPdir)/macros. Switch to GNU canonicalization. * mptests.am: Remove DEFS.
| | | | | | * Makefile.am: ACLOCAL_AMFLAGS= -I $(RTEMS_TOPdir)/macros. Switch to GNU canonicalization. * psxtests.am: Remove DEFS.
| | | | | | * Makefile.am: ACLOCAL_AMFLAGS= -I $(RTEMS_TOPdir)/macros. Switch to GNU canonicalization. * sample.am: Remove DEFS.
| | | | | | * Makefile.am: ACLOCAL_AMFLAGS= -I $(RTEMS_TOPdir)/macros. Switch to GNU canonicalization. * sptests.am: Remove DEFS.
| | | | | | * Makefile.am: ACLOCAL_AMFLAGS= -I $(RTEMS_TOPdir)/macros. Switch to GNU canonicalization. * tmitrontests.am: Remove DEFS.
| | | | | | * Makefile.am: ACLOCAL_AMFLAGS= -I $(RTEMS_TOPdir)/macros. Switch to GNU canonicalization. * tmtests.am: Remove DEFS.
* 2000-10-26 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-10-273-2/+11
| | | | | | | * Makefile.am: ACLOCAL_AMFLAGS= -I $(RTEMS_TOPdir)/macros. Switch to GNU canonicalization. * configure.in: Replace AC_CONFIG_SUBDIRS with RTEMS_CONFIG_BUILD_SUBDIRS.
* 2000-10-24 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-10-253-0/+7
| | | | | * psxmount/test.c, psxstat/test.c: Include <imfs.h> to get IMFS_ops. It was formerly incorrectly prototyped in <libio.h>.
* 2000-09-29 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-09-293-5/+19
| | | | | * sp20/sp20.scn: Corrected to reflect new addition. * sp20/system.h: Removed comment reflecting history.
* 2000-09-29 Stephan Merker <merker@decrc.abb.de>Joel Sherrill2000-09-295-13/+64
| | | | | | * sp20/getall.c, sp20/init.c, sp20/system.h, sp20/task1.c: Added new task to test sequence of altering a period's length while it is still active.
* 2000-09-04 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-09-053-0/+6
| | | | * stubdr/Makefile.am, wrapup/Makefile.am: Include compile.am
* 2000-09-04 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-09-0510-0/+16
| | | | | | | * base_mp/node1/Makefile.am, base_mp/node2/Makefile.am, base_sp/Makefile.am, cdtest/Makefile.am, hello/Makefile.am, minimum/Makefile.am, paranoia/Makefile.am, ticker/Makefile.am, unlimited/Makefile.am: Include compile.am
* 2000-09-04 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-09-052-0/+5
| | | | * tmitronsem01/Makefile.am: Include compile.am
* 2000-09-04 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-09-0524-0/+34
| | | | | | | | | | | * psx01/Makefile.am, psx02/Makefile.am, psx03/Makefile.am, psx04/Makefile.am, psx05/Makefile.am, psx06/Makefile.am, psx07/Makefile.am, psx08/Makefile.am, psx09/Makefile.am, psx10/Makefile.am, psx11/Makefile.am, psx12/Makefile.am, psx13/Makefile.am, psxcancel/Makefile.am, psxfile01/Makefile.am, psxhdrs/Makefile.am, psxmount/Makefile.am, psxmsgq01/Makefile.am, psxreaddir/Makefile.am, psxsem01/Makefile.am, psxstat/Makefile.am, psxtime/Makefile.am, psxtimer/Makefile.am: Include compile.am
* 2000-09-04 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-09-059-0/+14
| | | | | | * cpuuse/Makefile.am, malloctest/Makefile.am, monitor/Makefile.am, putenvtest/Makefile.am, rtems++/Makefile.am, rtmonuse/Makefile.am, stackchk/Makefile.am, termios/Makefile.am: Include compile.am
* 2000-09-04 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-09-0510-0/+17
| | | | | | | | * itronhello/Makefile.am, itronmbf01/Makefile.am, itronmbox01/Makefile.am, itronsem01/Makefile.am, itrontask01/Makefile.am, itrontask02/Makefile.am, itrontask03/Makefile.am, itrontask04/Makefile.am, itrontime01/Makefile.am: Include compile.am
* 2000-09-04 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-09-0529-0/+45
| | | | | | | | | | | | | | | | | * mp01/node1/Makefile.am, mp01/node2/Makefile.am, mp02/node1/Makefile.am, mp02/node2/Makefile.am, mp03/node1/Makefile.am, mp03/node2/Makefile.am, mp04/node1/Makefile.am, mp04/node2/Makefile.am, mp05/node1/Makefile.am, mp05/node2/Makefile.am, mp06/node1/Makefile.am, mp06/node2/Makefile.am, mp07/node1/Makefile.am, mp07/node2/Makefile.am, mp08/node1/Makefile.am, mp08/node2/Makefile.am, mp09/node1/Makefile.am, mp09/node2/Makefile.am, mp10/node1/Makefile.am, mp10/node2/Makefile.am, mp11/node1/Makefile.am, mp11/node2/Makefile.am, mp12/node1/Makefile.am, mp12/node2/Makefile.am, mp13/node1/Makefile.am, mp13/node2/Makefile.am, mp14/node1/Makefile.am, mp14/node2/Makefile.am: Include compile.am
* 2000-09-04 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-09-0532-0/+45
| | | | | | | | | | | | | | * tm01/Makefile.am, tm02/Makefile.am, tm03/Makefile.am, tm04/Makefile.am, tm05/Makefile.am, tm06/Makefile.am, tm07/Makefile.am, tm08/Makefile.am, tm09/Makefile.am, tm10/Makefile.am, tm11/Makefile.am, tm12/Makefile.am, tm13/Makefile.am, tm14/Makefile.am, tm15/Makefile.am, tm16/Makefile.am, tm17/Makefile.am, tm18/Makefile.am, tm19/Makefile.am, tm20/Makefile.am, tm21/Makefile.am, tm22/Makefile.am, tm23/Makefile.am, tm24/Makefile.am, tm25/Makefile.am, tm26/Makefile.am, tm27/Makefile.am, tm28/Makefile.am, tm29/Makefile.am, tmck/Makefile.am, tmoverhd/Makefile.am: Include compile.am
* 2000-09-04 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-09-0530-0/+42
| | | | | | | | | | | | | * sp01/Makefile.am, sp02/Makefile.am, sp03/Makefile.am, sp04/Makefile.am, sp05/Makefile.am, sp06/Makefile.am, sp07/Makefile.am, sp08/Makefile.am, sp09/Makefile.am, sp11/Makefile.am, sp12/Makefile.am, sp13/Makefile.am, sp14/Makefile.am, sp15/Makefile.am, sp16/Makefile.am, sp17/Makefile.am, sp19/Makefile.am, sp20/Makefile.am, sp21/Makefile.am, sp22/Makefile.am, sp23/Makefile.am, sp24/Makefile.am, sp25/Makefile.am, sp26/Makefile.am, sp27/Makefile.am, sp28/Makefile.am, sp29/Makefile.am, spfatal/Makefile.am, spsize/Makefile.am: Include compile.am
* 2000-08-31 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-09-0117-16/+25
| | | | | | | | | | * psx01/Makefile.am, psx02/Makefile.am, psx03/Makefile.am, psx04/Makefile.am, psx05/Makefile.am, psx06/Makefile.am, psx07/Makefile.am, psx08/Makefile.am, psx09/Makefile.am, psx10/Makefile.am, psx11/Makefile.am, psx11/Makefile.am, psx12/Makefile.am, psxcancel/Makefile.am, psxmsgq01/Makefile.am, psxsem01/Makefile.am, psxsem01/Makefile.am, psxtimer/Makefile.am: Use AM_CPPFLAGS += instead of AM_CPPFLAGS =
* Adding ChangeLogs.Joel Sherrill2000-08-1012-0/+34
* Added ifdef on C4x to avoid invalid address alignment checks since thereJoel Sherrill2000-07-263-0/+28
| | | | is no such thing on the C4x.
* Port of RTEMS to the Texas Instruments C3x/C4x DSP families includingJoel Sherrill2000-07-262-0/+17
| | | | | | | | | | | a BSP (c4xsim) supporting the simulator included with gdb. This port was done by Joel Sherrill and Jennifer Averett of OAR Corporation. Also included with this port is a space/time optimization to eliminate FP context switch management on CPUs without hardware or software FP. An issue with this port was that sizeof(unsigned32) = sizeof(unsigned8) on this CPU. This required addressing alignment checks and assumptions as well as fixing code that assumed sizeof(unsigned32) == 4.
