* | New test from Juan Zamorano Flores <jzamora@avellano.datsi.fi.upm.es> | Joel Sherrill | 1999-02-03 | 1 | -1/+1 | |
| | | | | that is part of the addition of POSIX timers. | |||||
* | New files from Juan Zamorano Flores <jzamora@avellano.datsi.fi.upm.es> | Joel Sherrill | 1999-02-03 | 4 | -0/+508 | |
| | | | | that are part of the addition of POSIX timers. | |||||
* | Removed unneeded include of libio_.h. | Joel Sherrill | 1999-01-31 | 1 | -2/+0 | |
* | Patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de> to rename all | Joel Sherrill | 1998-12-14 | 1 | -3/+3 | |
| | | | | | .s files to .S in conformance with GNU conventions. This is a minor step along the way to supporting automake. | |||||
* | Removed spaces. | Joel Sherrill | 1998-12-03 | 3 | -14/+0 | |
* | Changed to account for ownership only being tracked when a priority | Joel Sherrill | 1998-12-03 | 1 | -0/+8 | |
| | | | | blocking protocol is used. | |||||
* | Removed all ^M from the file. | Jennifer Averett | 1998-12-03 | 1 | -156/+156 | |
* | Added psx to the front of all test names. | Jennifer Averett | 1998-12-03 | 1 | -1/+1 | |
* | Removed all ^M from the scn file. | Jennifer Averett | 1998-12-03 | 1 | -1253/+1253 | |
* | Cleaned up test. | Jennifer Averett | 1998-12-03 | 7 | -320/+480 | |
| | | | | Updated scn files to match present expected test output. | |||||
* | Added Comment that a result is valid at 4 or 5 seconds. | Jennifer Averett | 1998-12-03 | 1 | -13/+1 | |
* | Updated scn files to match present expected test output. | Jennifer Averett | 1998-12-03 | 4 | -11/+267 | |
* | Renamed all directories to start with psx. | Jennifer Averett | 1998-12-03 | 4 | -4/+4 | |
* | Added a posix time test. | Jennifer Averett | 1998-12-03 | 1 | -2/+2 | |
| | | | | Renamed all directories to start with psx. | |||||
* | Modified to support test names longer than two characters plus the | Joel Sherrill | 1998-12-03 | 1 | -1/+1 | |
| | | | | | test suite designator. In English, we now support psxfile in addition to psx11. | |||||
* | Insure that the same output occurs when multiprocessing is disabled. | Joel Sherrill | 1998-12-03 | 5 | -1/+41 | |
* | Moved cpuuse.h to rtems subdirectory. | Joel Sherrill | 1998-12-03 | 1 | -1/+1 | |
* | Include files now installed as <rtems/*.h>. | Joel Sherrill | 1998-12-01 | 2 | -3/+3 | |
* | Added base version of file system infrastructure. This includes a major | Joel Sherrill | 1998-11-23 | 1 | -5/+17 | |
| | | | | | | | | | | | | | | | | | | | | | | | | overhaul of the RTEMS system call interface. This base file system is the "In-Memory File System" aka IMFS. The design and implementation was done by the following people: + Joel Sherrill (joel@OARcorp.com) + Jennifer Averett (jennifer@OARcorp.com) + Steve "Mr Mount" Salitasc (salitasc@OARcorp.com) + Kerwin Wade (wade@OARcorp.com) PROBLEMS ======== + It is VERY likely that merging this will break the UNIX port. This can/will be fixed. + There is likely some reentrancy/mutual exclusion needed. + Eventually, there should be a "mini-IMFS" description table to eliminate links, symlinks, etc to save memory. All you need to have "classic RTEMS" functionality is technically directories and device IO. All the rest could be left out to save memory. | |||||
* | Added new tests in support of the file system infrastructure. | Joel Sherrill | 1998-11-23 | 4 | -0/+218 | |
* | Added tests in support of the file system infrastructure. | Joel Sherrill | 1998-11-23 | 28 | -1/+5240 | |
* | Added --disable-multiprocessing flag and modified a lot of files to make | Joel Sherrill | 1998-11-23 | 1 | -3/+35 | |
| | | | | it work. | |||||
* | New file based on information from Eric Norum <eric@skatter.usask.ca>. | Joel Sherrill | 1998-10-05 | 1 | -0/+42 | |
* | Fixed use of incorrect macro for minimum stack size. | Joel Sherrill | 1998-10-05 | 1 | -1/+1 | |
* | IDLE task stack size now specified as a field in the CPU Table for all | Joel Sherrill | 1998-09-23 | 1 | -1/+1 | |
| | | | | ports. | |||||
* | Under allcoated task stacks. | Joel Sherrill | 1998-08-03 | 1 | -1/+1 | |
* | Moved to network demos | Joel Sherrill | 1998-08-01 | 1 | -8/+1 | |
* | Patch from Eric Valette <valette@crf.canon.fr> and Emmanuel Raguet | Joel Sherrill | 1998-07-24 | 1 | -2/+11 | |
| | | | | <raguet@crf.canon.fr> to make their patches work together. | |||||
* | Patch from Emmanuel Raguet <raguet@crf.canon.fr>: | Joel Sherrill | 1998-07-23 | 1 | -1/+3 | |
| | | | | | | | | | | | | Here is a patch for KA9Q stack. This patch contains an Ethernet Driver for Western Digital, some fixes for the UDP and TCP protocols (for endian conversion) and some little programs which allow the test of UDP and TCP sockets via Ethernet. I have tested that on an Intel machine. If someone can test it on a big-endian machine, ... | |||||
* | Turned stack checker on. | Joel Sherrill | 1998-07-17 | 1 | -0/+2 | |
* | Patch from Eric Norum to avoid printing from context switch user extension. | Joel Sherrill | 1998-06-12 | 3 | -7/+37 | |
| | | | | The array is too long and needs to be shortened. | |||||
* | Fixed comment block at the beginning of the file for a copyright date | Joel Sherrill | 1998-06-09 | 135 | -271/+270 | |
| | | | | problem and an English problem. | |||||
* | Fixed prototype of Fatal_Extension. | Joel Sherrill | 1998-05-04 | 2 | -18/+15 | |
| | | | | Fixed interface to cofndefs.h for initial extension set. | |||||
* | botched file -- removed from repository and readded | Joel Sherrill | 1998-04-30 | 1 | -0/+14 | |
* | Added support for debug variants on tests. | Joel Sherrill | 1998-04-29 | 1 | -4/+5 | |
* | Added CONFIGURE_EXTRA_TASK_STACKS definition to make memory requirements | Joel Sherrill | 1998-04-27 | 24 | -3/+49 | |
| | | | | more accurate. | |||||
* | Fixed screen to match actual output. | Joel Sherrill | 1998-04-27 | 1 | -3/+2 | |
* | Reset the pthread attributes structure so the proper error would be | Joel Sherrill | 1998-04-27 | 1 | -1/+5 | |
| | | | | generated. | |||||
* | Initial sets of user extensions now have memory allocated on the fly | Joel Sherrill | 1998-04-15 | 1 | -2/+1 | |
| | | | | for them. | |||||
* | Increased stack size so test would run in debug mode. | Joel Sherrill | 1998-04-06 | 5 | -5/+6 | |
* | Were looking at the wrong C++ variable. | Joel Sherrill | 1998-03-30 | 1 | -1/+1 | |
* | HAS_CPLUSPLUS should have been RTEMS_HAS_CPLUSPLUS. | Joel Sherrill | 1998-03-26 | 1 | -1/+1 | |
* | Rename hppa1_1 to hppa1.1 and switched to using __XXX__ macros for | Joel Sherrill | 1998-03-24 | 2 | -9/+7 | |
| | | | | the CPU family name constants. | |||||
* | Corrected typo in copyright notice. | Joel Sherrill | 1998-03-21 | 1 | -1/+1 | |
* | Corrected to indicate test cases which were skipped. | Joel Sherrill | 1998-03-03 | 1 | -2/+2 | |
* | Modified to reflect new restrictions on mutex being released. | Joel Sherrill | 1998-02-20 | 1 | -1/+1 | |
* | Removed extra line. | Joel Sherrill | 1998-02-20 | 1 | -1/+0 | |
* | Increased stack space to let test run to completion. | Joel Sherrill | 1998-02-20 | 1 | -4/+4 | |
* | Increased stack space of tasks. | Joel Sherrill | 1998-02-19 | 1 | -1/+1 | |
* | Increased stack size of initialization task. | Joel Sherrill | 1998-02-19 | 1 | -0/+1 | |
