path: root/c/src/tests (unfollow)
2001-05-112001-05-10 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2-9/+5
* configure.in: Remove RTEMS_PROG_CC_FOR_TARGET, RTEMS_PROG_CXX_FOR_TARGET, RTEMS_CANONICALIZE_TOOLS.
2001-05-102001-05-10 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill18-9/+45
2001-04-242001-04-24 Joel Sherrill <joel@OARcorp.com>Joel Sherrill3-0/+56
* psxfile01/test.c, psxfile01/psxfile01.scn : Added test case for open, write, reopen, append twice from Andrew Bythell <abythell@nortelnetworks.com> that tripped an initialization problem in the IMFS.
2001-04-202001-04-20 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2-0/+7
* sp298/sp28.scn: Minor adjustment so test output matches the screen file.
2001-04-202001-04-20 Joel Sherrill <joel@OARcorp.com>Joel Sherrill12-309/+306
* psx04/init.c, psx04/psx04.scn, psx07/init.c, psx07/psx07.scn, psxfile01/psxfile01.scn, psxmsgq01/psxmsgq01.scn, psxreaddir/test.c, psxstat/psxstat.scn, psxstat/test.c, psxtime/psxtime.scn, psxtimer/psxtimer.scn: Various adjustments so test output matches screens more reliably.
2001-04-202001-04-20 Joel Sherrill <joel@OARcorp.com>Joel Sherrill5-6/+12
* itronmbf01/itronmbf01.scn, itronmbox01/init.c, itronsem01/itronsem01.scn, itrontime01/init.c: Various adjustments so test output matches screens more reliably.
2001-02-122001-02-07 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2-1/+5
* spsize/size.c: Use #if !defined(RTEMS_UNIX).
2001-01-262001-01-26 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill14-350/+11
* configure.in: Remove stubdr, wrapup, AC_INIT(include). * Makefile.am: Remove stubdr, wrapup. * stubdr/Makefile.am, stubdr/open.c, stubdr/close.c, stubdr/init.c, stubdr/stubdrv.h, stubdr/cntrl.c, stubdr/.cvsignore, stubdr/read.c, stubdr/write.c, wrapup/Makefile.am, wrapup/.cvsignore, stubdr/, wrapup/: Remove.
2001-01-262001-01-26 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2-1/+5
* tm20/Makefile.am: Remove stubdir.rel
2001-01-262001-01-26 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2-2/+4
* sp21/Makefile.am: Remove libtest.
2001-01-252001-01-25 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2-5/+7
* psx01/psx01.scn: Corrected to reflect clock_getres() now working.
2000-11-202000-11-17 Jennifer Averett <jennifer@OARcorp.com>Jennifer Averett1-0/+14
* psxstat/test.c, psxstat/psxstat.scn: Forced inode numbers to remain consistant across platforms and bsps by forcing a mount point in front of all paths. 2000-11-17 Jennifer Averret <jennifer@OARcorp.com> * psxmount/test.c, psxmount/psxmount.scn: Improve output to report expected error condition in one case. * psxreaddir/test.c, psxreaddir.scn: Added test cases to exercise readdir() of root of mounted filesystem. Also corrected the screen file for some mistakes noticed in this effort.
2000-11-202000-11-17 Jennifer Averret <jennifer@OARcorp.com>Jennifer Averett2-17/+16
2000-11-202000-11-20 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2-0/+6
* itrontask01/system.h: Configure enough stack memory.
2000-11-172000-11-17 Jennifer Averret <jennifer@OARcorp.com>Jennifer Averett2-290/+267
2000-11-172000-11-17 Jennifer Averret <jennifer@OARcorp.com>Jennifer Averett4-81/+143
2000-11-152000-11-13 Joel Sherrill <joel@OARcorp.com>Joel Sherrill3-2/+6
* psxmount/psxmount.scn, psxmount/test.c: Correct spelling.
2000-11-092000-11-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill24-12/+60
2000-11-022000-11-02 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2-1/+5
* stubdr/Makefile.am: Replace leaf.cfg w/ automake/lib.am.
2000-11-022000-11-02 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill24-12/+60
2000-11-012000-11-01 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2-1/+7
* malloctest/task1.c: assoc.h, error.h, libio_.h, libio.h, and libcsupport.h moved from libc to lib/include/rtems and now must be referenced as <rtems/XXX.h>.
2000-10-312000-10-30 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2-1/+9
* POSIX include files merged into newlib. This resulted in some definitions moving to other files and thus some secondary effects in RTEMS source code. * paranoia/paranoia.c: Commented out incorrect and conflicting prototype of read().
2000-10-272000-10-26 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill6-3/+18
* Makefile.am: ACLOCAL_AMFLAGS= -I $(RTEMS_TOPdir)/macros. Switch to GNU canonicalization.
2000-10-272000-10-26 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill3-2/+8
* Makefile.am: ACLOCAL_AMFLAGS= -I $(RTEMS_TOPdir)/macros. Switch to GNU canonicalization. * itrontests.am: Remove DEFS.
* Makefile.am: ACLOCAL_AMFLAGS= -I $(RTEMS_TOPdir)/macros. Switch to GNU canonicalization. * libtests.am: Remove DEFS.
* Makefile.am: ACLOCAL_AMFLAGS= -I $(RTEMS_TOPdir)/macros. Switch to GNU canonicalization. * mptests.am: Remove DEFS.
* Makefile.am: ACLOCAL_AMFLAGS= -I $(RTEMS_TOPdir)/macros. Switch to GNU canonicalization. * psxtests.am: Remove DEFS.
* Makefile.am: ACLOCAL_AMFLAGS= -I $(RTEMS_TOPdir)/macros. Switch to GNU canonicalization. * sample.am: Remove DEFS.
* Makefile.am: ACLOCAL_AMFLAGS= -I $(RTEMS_TOPdir)/macros. Switch to GNU canonicalization. * sptests.am: Remove DEFS.
* Makefile.am: ACLOCAL_AMFLAGS= -I $(RTEMS_TOPdir)/macros. Switch to GNU canonicalization. * tmitrontests.am: Remove DEFS.
* Makefile.am: ACLOCAL_AMFLAGS= -I $(RTEMS_TOPdir)/macros. Switch to GNU canonicalization. * tmtests.am: Remove DEFS.
2000-10-272000-10-26 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill3-2/+11
* Makefile.am: ACLOCAL_AMFLAGS= -I $(RTEMS_TOPdir)/macros. Switch to GNU canonicalization. * configure.in: Replace AC_CONFIG_SUBDIRS with RTEMS_CONFIG_BUILD_SUBDIRS.
2000-10-252000-10-24 Joel Sherrill <joel@OARcorp.com>Joel Sherrill3-0/+7
* psxmount/test.c, psxstat/test.c: Include <imfs.h> to get IMFS_ops. It was formerly incorrectly prototyped in <libio.h>.
2000-09-292000-09-29 Joel Sherrill <joel@OARcorp.com>Joel Sherrill3-5/+19
* sp20/sp20.scn: Corrected to reflect new addition. * sp20/system.h: Removed comment reflecting history.
2000-09-292000-09-29 Stephan Merker <merker@decrc.abb.de>Joel Sherrill5-13/+64
* sp20/getall.c, sp20/init.c, sp20/system.h, sp20/task1.c: Added new task to test sequence of altering a period's length while it is still active.
2000-09-052000-09-04 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill3-0/+6
* stubdr/Makefile.am, wrapup/Makefile.am: Include compile.am
2000-09-052000-09-04 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill10-0/+16
* base_mp/node1/Makefile.am, base_mp/node2/Makefile.am, base_sp/Makefile.am, cdtest/Makefile.am, hello/Makefile.am, minimum/Makefile.am, paranoia/Makefile.am, ticker/Makefile.am, unlimited/Makefile.am: Include compile.am
2000-09-052000-09-04 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2-0/+5
* tmitronsem01/Makefile.am: Include compile.am
2000-09-052000-09-04 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill24-0/+34
* psx01/Makefile.am, psx02/Makefile.am, psx03/Makefile.am, psx04/Makefile.am, psx05/Makefile.am, psx06/Makefile.am, psx07/Makefile.am, psx08/Makefile.am, psx09/Makefile.am, psx10/Makefile.am, psx11/Makefile.am, psx12/Makefile.am, psx13/Makefile.am, psxcancel/Makefile.am, psxfile01/Makefile.am, psxhdrs/Makefile.am, psxmount/Makefile.am, psxmsgq01/Makefile.am, psxreaddir/Makefile.am, psxsem01/Makefile.am, psxstat/Makefile.am, psxtime/Makefile.am, psxtimer/Makefile.am: Include compile.am
2000-09-052000-09-04 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill9-0/+14
* cpuuse/Makefile.am, malloctest/Makefile.am, monitor/Makefile.am, putenvtest/Makefile.am, rtems++/Makefile.am, rtmonuse/Makefile.am, stackchk/Makefile.am, termios/Makefile.am: Include compile.am
2000-09-052000-09-04 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill10-0/+17
* itronhello/Makefile.am, itronmbf01/Makefile.am, itronmbox01/Makefile.am, itronsem01/Makefile.am, itrontask01/Makefile.am, itrontask02/Makefile.am, itrontask03/Makefile.am, itrontask04/Makefile.am, itrontime01/Makefile.am: Include compile.am
2000-09-052000-09-04 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill29-0/+45
* mp01/node1/Makefile.am, mp01/node2/Makefile.am, mp02/node1/Makefile.am, mp02/node2/Makefile.am, mp03/node1/Makefile.am, mp03/node2/Makefile.am, mp04/node1/Makefile.am, mp04/node2/Makefile.am, mp05/node1/Makefile.am, mp05/node2/Makefile.am, mp06/node1/Makefile.am, mp06/node2/Makefile.am, mp07/node1/Makefile.am, mp07/node2/Makefile.am, mp08/node1/Makefile.am, mp08/node2/Makefile.am, mp09/node1/Makefile.am, mp09/node2/Makefile.am, mp10/node1/Makefile.am, mp10/node2/Makefile.am, mp11/node1/Makefile.am, mp11/node2/Makefile.am, mp12/node1/Makefile.am, mp12/node2/Makefile.am, mp13/node1/Makefile.am, mp13/node2/Makefile.am, mp14/node1/Makefile.am, mp14/node2/Makefile.am: Include compile.am
2000-09-052000-09-04 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill32-0/+45
* tm01/Makefile.am, tm02/Makefile.am, tm03/Makefile.am, tm04/Makefile.am, tm05/Makefile.am, tm06/Makefile.am, tm07/Makefile.am, tm08/Makefile.am, tm09/Makefile.am, tm10/Makefile.am, tm11/Makefile.am, tm12/Makefile.am, tm13/Makefile.am, tm14/Makefile.am, tm15/Makefile.am, tm16/Makefile.am, tm17/Makefile.am, tm18/Makefile.am, tm19/Makefile.am, tm20/Makefile.am, tm21/Makefile.am, tm22/Makefile.am, tm23/Makefile.am, tm24/Makefile.am, tm25/Makefile.am, tm26/Makefile.am, tm27/Makefile.am, tm28/Makefile.am, tm29/Makefile.am, tmck/Makefile.am, tmoverhd/Makefile.am: Include compile.am
2000-09-052000-09-04 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill30-0/+42
* sp01/Makefile.am, sp02/Makefile.am, sp03/Makefile.am, sp04/Makefile.am, sp05/Makefile.am, sp06/Makefile.am, sp07/Makefile.am, sp08/Makefile.am, sp09/Makefile.am, sp11/Makefile.am, sp12/Makefile.am, sp13/Makefile.am, sp14/Makefile.am, sp15/Makefile.am, sp16/Makefile.am, sp17/Makefile.am, sp19/Makefile.am, sp20/Makefile.am, sp21/Makefile.am, sp22/Makefile.am, sp23/Makefile.am, sp24/Makefile.am, sp25/Makefile.am, sp26/Makefile.am, sp27/Makefile.am, sp28/Makefile.am, sp29/Makefile.am, spfatal/Makefile.am, spsize/Makefile.am: Include compile.am
2000-09-012000-08-31 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill17-16/+25
* psx01/Makefile.am, psx02/Makefile.am, psx03/Makefile.am, psx04/Makefile.am, psx05/Makefile.am, psx06/Makefile.am, psx07/Makefile.am, psx08/Makefile.am, psx09/Makefile.am, psx10/Makefile.am, psx11/Makefile.am, psx11/Makefile.am, psx12/Makefile.am, psxcancel/Makefile.am, psxmsgq01/Makefile.am, psxsem01/Makefile.am, psxsem01/Makefile.am, psxtimer/Makefile.am: Use AM_CPPFLAGS += instead of AM_CPPFLAGS =
2000-08-10Adding ChangeLogs.Joel Sherrill12-0/+34
2000-07-26Added ifdef on C4x to avoid invalid address alignment checks since thereJoel Sherrill3-0/+28
is no such thing on the C4x.
2000-07-26Port of RTEMS to the Texas Instruments C3x/C4x DSP families includingJoel Sherrill2-0/+17
a BSP (c4xsim) supporting the simulator included with gdb. This port was done by Joel Sherrill and Jennifer Averett of OAR Corporation. Also included with this port is a space/time optimization to eliminate FP context switch management on CPUs without hardware or software FP. An issue with this port was that sizeof(unsigned32) = sizeof(unsigned8) on this CPU. This required addressing alignment checks and assumptions as well as fixing code that assumed sizeof(unsigned32) == 4.
2000-07-13Switch logical in conditional.Joel Sherrill1-1/+1
2000-07-13Patch rtems-rc-20000713-1-cvs.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill48-77/+79
that is yet another multilib-related structual cleanup patch: Changes: * Make RTEMS_TEST_NO_PAUSE a tests/ subpackage specific option. - Remove RTEMS_TEST_NO_PAUSE from custom/*.cfg, targopts.h and cpuopts.h. - Add autoconf macros RTEMS_*_RTEMS_TEST_NO_PAUSE (aclocal/rtems-test-no-pause.m4). - Add RTEMS_*_RTEMS_TEST_NO_PAUSE support to sptests/configure.ins and tmtests/configure.in. These are the only subdirectories which currently apply RTEMS_TEST_NO_PAUSE. - Add autoconf-DEFS support to all test subpackages' configure.ins below tests/. I.e. AC_DEFINES now get explicitly propagated as preprocessor defines into Makefiles, cf. AM_CPPFLAGS in tests/*/*.am, instead of using a global config-files. - Remove NDEBUG from custom/*.cfg. * AC_DEFINE POSIX_API, ITRON_API and MULTIPROCESSING in exec/configure.in, only. - All other sources now should relay on the values from cpuopts.h and should not define them themselves. - Several related changes to many configure.ins * Bug-fixes to RTEMS_*_RTEMS_DEBUG macros (Actually workarounds to quoting bugs in autoconf). Notes: * This patch is rather immature and only tested for a small subset of BSPs (requires the tests to be enabled and therefore takes an tremendous amount of disc space and time.) * The patches to *cfg were generated by a script. Expect file formating changes :)
