to fail sporadically.
an array sizing coding error.
addition.
addition.
which ontains all what was left over from the other patches (Primarily
minor configuration cleanups).
patch -p1 < rtems-rc-19991203-9.diff
./bootstrap
which does minor cleanup for Makefile.ams below mptests, which only
removes some bogus comments from the Makefile.ams.
patch -p1 < rtems-rc-19991203-8.diff
./bootstrap
too small when OPERATION_COUNT is less than 10.
and his EPICS porting effort.
<corsepiu@faw.uni-ulm.de>:
The patch below provides
before)
rtems-rc-19991123-rc-2.diff
Attention:
the opportunity to work with it.
<corsepiu@faw.uni-ulm.de> which converted fiels to automake.
Addtional major bugs:
to convert the tests/support directory from Makefile.in to Makefile.am.
<corsepiu@faw.uni-ulm.de>.
in the previous commits.
to convert the psxtests directory from Makefile.in to Makefile.am.
to convert the tmtests directory from Makefile.in to Makefile.am.
to convert the sample tests to automake.
by the same application.
+ Added tests for sem_open, sem_close, and sem_unlink.
+ Yellow lined sem_open, sem_close, sem_unlink,
_POSIX_Semaphore_Delete, _POSIX_Semaphore_Name_to_id,
and _POSIX_Semaphore_Create_support. Except for MP, pshared
OBJECT_REMOTE, and out of memory paths.
can be included from the same file.
*.cfg files.
dependencies
automake and RTEMS make rules
convention)
performs automatically.
WARNING:
Makefile.ams.
family of macros to produce better checks and diagnostic messages.
