path: root/c/src/tests (follow)
* 2001-11-26 Ralf CorsepiusJoel Sherrill2001-11-262-1/+4
| | | | * cdtest/main.cc: Remove RTEMS_TEST_IO_STREAM.
* 2001-11-08 Jiri Gaisler <jiri@gaisler.com>Joel Sherrill2001-11-082-7/+21
| | | | | | | This fix is response to test results reported by Jerry Needell <jerry.needell@unh.edu> for the SPARC/ERC32 and tracked as PR80. * tm27/task1.c: Account for overhead in starting and stopping the timer.
* 2001-11-07 Jennifer Averett <jennifer@OARcorp.com>Joel Sherrill2001-11-072-1/+12
| | | | | | | | Reported by Ibragimov Ilya <ibr@oktet.ru> and tracked as PR63. * psxstat/test.c: Fix test ENOTDIR to correspond to chdir() change. Since we check permissions before evaluating enough to see if it a regular file or directory, this hack is needed to make the regular file executable.
* 2001-11-07 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-11-071-2/+7
| | | | | | Tracked as PR72 but related to the object id problem (PR36) reported by Todor.Todorov@barco.com. * include/tmacros.h: Added fatal_directive_check_status_only().
* 2001-11-07 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-11-071-0/+6
| | | | | | | Tracked as PR72 but related to the object id problem (PR36) reported by Todor.Todorov@barco.com. but discovered independently. * include/tmacros.h: Added fatal_directive_check_status_only().
* 2001-11-07 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-11-074-3/+12
| | | | | | | | Tracked as PR72 but related to the object id problem (PR36) reported by Todor.Todorov@barco.com. * mp03/delay.c: Dispatch disable level is actually 1 not 0. * mp13/system.h: Configure enough tasks (CONFIGURE_MAXIMUM_TASKS=3). * mp14/delay.c: Dispatch disable level may be arbitrarily > 0.
* 2001-11-01 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-11-012-0/+7
| | | | | | * sp26/system.h: Properly account for stack memory used by this test. Reported by Jerry Needell <jerry.needell@unh.edu> and processed as PR78.
* 2001-11-01 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-11-012-1/+8
| | | | | | * rtems++/Makefile.am: Make sure debug variant of librtems++ is linked against. Reported by Jerry Needell <jerry.needell@unh.edu> and processed as PR78.
* 2001-10-25 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-10-252-1/+5
| | | | * rtems++/Makefile.am: Pick up -lrtems++ even when debug.
* 2001-10-25 Eric Norum <eric.norum@usask.ca>Joel Sherrill2001-10-252-0/+6
| | | | | * cdtest/system.h: Configure 1 semaphore. This probably covers up not defining one for the GCC C++ Run-Time Libraries.
* 2001-10-17 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-10-172-1/+5
| | | | * paranoia/Makefile.am: Use LD_LIBS = -lm to make automake-1.5 happy.
* 2001-10-17 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-10-173-4/+7
| | | | | * configure.ac: Apply RTEMS_CPU_SUBDIRS for potential CPU-subdirs. * Makefile.am: Require automake-1.5.
* 2001-10-12 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-10-127-6/+6
| | | | | | * unlimited/init.c, unlimited/system.h, unlimited/test1.c, unlimited/test2.c, unlimited/test3.c, unlimited/unlimited.doc: Fixed typo.
* 2001-10-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-10-1212-0/+665
| | | | | * .cvsignore: Add autom4te.cache for autoconf > 2.52. * configure.in: Remove.
* 2001-10-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-10-1212-651/+0
* 2001-10-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-10-1124-0/+84
* 2001-09-23 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-09-272-1/+5
| | | | * Makefile.am: Use 'PREINSTALL_FILES ='.
* 2001-09-23 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-09-272-1/+3
| | | | | * libtests.am: Use TMPINSTALL_FILES = to make automake-1.5 happy. * rtems++/Makefile.am: LD_FLAGS = -lrtems++.
* 2001-09-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-09-242-1/+5
| | | | * tmtests.am: Use TMPINSTALL_FILES = to make automake-1.5 happy.
| | | | * tmitrontests.am: Use TMPINSTALL_FILES = to make automake-1.5 happy.
| | | | * sptests.am: Use TMPINSTALL_FILES = to make automake-1.5 happy.
* 2001-09-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-09-241-2/+0
| | | | | | * minimum/Makefile.am: Fix comments to make automake-1.5 happy. * sample.am: Use TMPINSTALL_FILES = to make automake-1.5 happy. * cdtest/Makefile.am: Remove LD_LIBS.
| | | | * psxtests.am: Use TMPINSTALL_FILES = to make automake-1.5 happy.
| | | | * mptests.am: Use TMPINSTALL_FILES = to make automake-1.5 happy.
* 2001-09-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-09-243-3/+6
| | | | | * libtests.am: Use TMPINSTALL_FILES = to make automake-1.5 happy. * rtems++/Makefile: Remove LD_LIBS.
| | | | * itrontests.am: Use TMPINSTALL_FILES = to make automake-1.5 happy.
* 2001-09-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-09-243-2/+8
* 2001-09-19 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-09-1932-31/+65
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * tm27/Makefile.am: include leaf.am instead of leaf.cfg. * tm26/Makefile.am: include leaf.am instead of leaf.cfg. * tm24/Makefile.am: include leaf.am instead of leaf.cfg. * tm16/Makefile.am: include leaf.am instead of leaf.cfg. * tm18/Makefile.am: include leaf.am instead of leaf.cfg. * tm02/Makefile.am: include leaf.am instead of leaf.cfg. * tm10/Makefile.am: include leaf.am instead of leaf.cfg. * tm11/Makefile.am: include leaf.am instead of leaf.cfg. * tm15/Makefile.am: include leaf.am instead of leaf.cfg. * tm19/Makefile.am: include leaf.am instead of leaf.cfg. * tm04/Makefile.am: include leaf.am instead of leaf.cfg. * tm17/Makefile.am: include leaf.am instead of leaf.cfg. * tm28/Makefile.am: include leaf.am instead of leaf.cfg. * tmck/Makefile.am: include leaf.am instead of leaf.cfg. * tm08/Makefile.am: include leaf.am instead of leaf.cfg. * tm12/Makefile.am: include leaf.am instead of leaf.cfg. * tm03/Makefile.am: include leaf.am instead of leaf.cfg. * tm13/Makefile.am: include leaf.am instead of leaf.cfg. * tm29/Makefile.am: include leaf.am instead of leaf.cfg. * tmoverhd/Makefile.am: include leaf.am instead of leaf.cfg. * tm20/Makefile.am: include leaf.am instead of leaf.cfg. * tm09/Makefile.am: include leaf.am instead of leaf.cfg. * tm01/Makefile.am: include leaf.am instead of leaf.cfg. * tm21/Makefile.am: include leaf.am instead of leaf.cfg. * tm07/Makefile.am: include leaf.am instead of leaf.cfg. * tm25/Makefile.am: include leaf.am instead of leaf.cfg. * tm22/Makefile.am: include leaf.am instead of leaf.cfg. * tm06/Makefile.am: include leaf.am instead of leaf.cfg. * tm05/Makefile.am: include leaf.am instead of leaf.cfg. * tm14/Makefile.am: include leaf.am instead of leaf.cfg. * tm23/Makefile.am: include leaf.am instead of leaf.cfg.
* 2001-09-19 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-09-192-1/+5
| | | | * tmitronsem01/Makefile.am: include leaf.am instead of leaf.cfg.
* 2001-09-19 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-09-1930-29/+61
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * sp20/Makefile.am: include leaf.am instead of leaf.cfg. * sp02/Makefile.am: include leaf.am instead of leaf.cfg. * sp19/Makefile.am: include leaf.am instead of leaf.cfg. * sp11/Makefile.am: include leaf.am instead of leaf.cfg. * sp25/Makefile.am: include leaf.am instead of leaf.cfg. * sp04/Makefile.am: include leaf.am instead of leaf.cfg. * spsize/Makefile.am: include leaf.am instead of leaf.cfg. * sp01/Makefile.am: include leaf.am instead of leaf.cfg. * sp16/Makefile.am: include leaf.am instead of leaf.cfg. * sp05/Makefile.am: include leaf.am instead of leaf.cfg. * sp09/Makefile.am: include leaf.am instead of leaf.cfg. * spfatal/Makefile.am: include leaf.am instead of leaf.cfg. * sp06/Makefile.am: include leaf.am instead of leaf.cfg. * sp23/Makefile.am: include leaf.am instead of leaf.cfg. * sp28/Makefile.am: include leaf.am instead of leaf.cfg. * sp03/Makefile.am: include leaf.am instead of leaf.cfg. * sp29/Makefile.am: include leaf.am instead of leaf.cfg. * sp13/Makefile.am: include leaf.am instead of leaf.cfg. * sp27/Makefile.am: include leaf.am instead of leaf.cfg. * sp14/Makefile.am: include leaf.am instead of leaf.cfg. * sp07/Makefile.am: include leaf.am instead of leaf.cfg. * sp15/Makefile.am: include leaf.am instead of leaf.cfg. * sp17/Makefile.am: include leaf.am instead of leaf.cfg. * sp22/Makefile.am: include leaf.am instead of leaf.cfg. * sp12/Makefile.am: include leaf.am instead of leaf.cfg. * sp26/Makefile.am: include leaf.am instead of leaf.cfg. * sp21/Makefile.am: include leaf.am instead of leaf.cfg. * sp24/Makefile.am: include leaf.am instead of leaf.cfg. * sp08/Makefile.am: include leaf.am instead of leaf.cfg.
* 2001-09-19 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-09-1910-10/+23
| | | | | | | | | | | | | * unlimited/Makefile.am: include leaf.am instead of leaf.cfg. * base_mp/node2/Makefile.am: include leaf.am instead of leaf.cfg. * base_mp/node1/Makefile.am: include leaf.am instead of leaf.cfg. * hello/Makefile.am: include leaf.am instead of leaf.cfg. * base_sp/Makefile.am: include leaf.am instead of leaf.cfg. * paranoia/Makefile.am: include leaf.am instead of leaf.cfg. * cdtest/Makefile.am: include leaf.am instead of leaf.cfg, use make-cxx-exe. * ticker/Makefile.am: include leaf.am instead of leaf.cfg. * minimum/Makefile.am: include leaf.am instead of leaf.cfg.
* 2001-09-19 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-09-1925-24/+51
| | | | | | | | | | | | | | | | | | | | | | | | | | | * psx01/Makefile.am: include leaf.am instead of leaf.cfg. * psx11/Makefile.am: include leaf.am instead of leaf.cfg. * psxcancel/Makefile.am: include leaf.am instead of leaf.cfg. * psx02/Makefile.am: include leaf.am instead of leaf.cfg. * psx13/Makefile.am: include leaf.am instead of leaf.cfg. * psxtime/Makefile.am: include leaf.am instead of leaf.cfg. * psxchroot01/Makefile.am: include leaf.am instead of leaf.cfg. * psx07/Makefile.am: include leaf.am instead of leaf.cfg. * psxmsgq01/Makefile.am: include leaf.am instead of leaf.cfg. * psxtimer/Makefile.am: include leaf.am instead of leaf.cfg. * psx10/Makefile.am: include leaf.am instead of leaf.cfg. * psx08/Makefile.am: include leaf.am instead of leaf.cfg. * psxhdrs/Makefile.am: include leaf.am instead of leaf.cfg. * psxfile01/Makefile.am: include leaf.am instead of leaf.cfg. * psx05/Makefile.am: include leaf.am instead of leaf.cfg. * psx09/Makefile.am: include leaf.am instead of leaf.cfg. * psxmount/Makefile.am: include leaf.am instead of leaf.cfg. * psxstat/Makefile.am: include leaf.am instead of leaf.cfg. * psx12/Makefile.am: include leaf.am instead of leaf.cfg. * psxreaddir/Makefile.am: include leaf.am instead of leaf.cfg. * psxsem01/Makefile.am: include leaf.am instead of leaf.cfg. * psx03/Makefile.am: include leaf.am instead of leaf.cfg. * psx04/Makefile.am: include leaf.am instead of leaf.cfg. * psx06/Makefile.am: include leaf.am instead of leaf.cfg.
* 2001-09-19 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-09-1929-28/+59
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * mp02/node2/Makefile.am: include leaf.am instead of leaf.cfg. * mp02/node1/Makefile.am: include leaf.am instead of leaf.cfg. * mp04/node2/Makefile.am: include leaf.am instead of leaf.cfg. * mp04/node1/Makefile.am: include leaf.am instead of leaf.cfg. * mp14/node2/Makefile.am: include leaf.am instead of leaf.cfg. * mp14/node1/Makefile.am: include leaf.am instead of leaf.cfg. * mp06/node2/Makefile.am: include leaf.am instead of leaf.cfg. * mp06/node1/Makefile.am: include leaf.am instead of leaf.cfg. * mp08/node2/Makefile.am: include leaf.am instead of leaf.cfg. * mp08/node1/Makefile.am: include leaf.am instead of leaf.cfg. * mp03/node2/Makefile.am: include leaf.am instead of leaf.cfg. * mp03/node1/Makefile.am: include leaf.am instead of leaf.cfg. * mp10/node2/Makefile.am: include leaf.am instead of leaf.cfg. * mp10/node1/Makefile.am: include leaf.am instead of leaf.cfg. * mp05/node2/Makefile.am: include leaf.am instead of leaf.cfg. * mp05/node1/Makefile.am: include leaf.am instead of leaf.cfg. * mp13/node2/Makefile.am: include leaf.am instead of leaf.cfg. * mp13/node1/Makefile.am: include leaf.am instead of leaf.cfg. * mp01/node2/Makefile.am: include leaf.am instead of leaf.cfg. * mp01/node1/Makefile.am: include leaf.am instead of leaf.cfg. * mp07/node2/Makefile.am: include leaf.am instead of leaf.cfg. * mp07/node1/Makefile.am: include leaf.am instead of leaf.cfg. * mp11/node2/Makefile.am: include leaf.am instead of leaf.cfg. * mp11/node1/Makefile.am: include leaf.am instead of leaf.cfg. * mp12/node2/Makefile.am: include leaf.am instead of leaf.cfg. * mp12/node1/Makefile.am: include leaf.am instead of leaf.cfg. * mp09/node2/Makefile.am: include leaf.am instead of leaf.cfg. * mp09/node1/Makefile.am: include leaf.am instead of leaf.cfg.
* 2001-09-19 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-09-199-9/+21
| | | | | | | | | | | | * malloctest/Makefile.am: include leaf.am instead of leaf.cfg. * monitor/Makefile.am: include leaf.am instead of leaf.cfg. * termios/Makefile.am: include leaf.am instead of leaf.cfg. * putenvtest/Makefile.am: include leaf.am instead of leaf.cfg. * rtems++/Makefile.am: include leaf.am instead of leaf.cfg, use make-cxx-exe. * stackchk/Makefile.am: include leaf.am instead of leaf.cfg. * rtmonuse/Makefile.am: include leaf.am instead of leaf.cfg. * cpuuse/Makefile.am: include leaf.am instead of leaf.cfg.
* 2001-09-19 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-09-1910-9/+21
| | | | | | | | | | | | * itrontask03/Makefile.am: include leaf.am instead of leaf.cfg. * itrontask04/Makefile.am: include leaf.am instead of leaf.cfg. * itronmbf01/Makefile.am: include leaf.am instead of leaf.cfg. * itronsem01/Makefile.am: include leaf.am instead of leaf.cfg. * itronhello/Makefile.am: include leaf.am instead of leaf.cfg. * itrontime01/Makefile.am: include leaf.am instead of leaf.cfg. * itrontask01/Makefile.am: include leaf.am instead of leaf.cfg. * itrontask02/Makefile.am: include leaf.am instead of leaf.cfg. * itronmbox01/Makefile.am: include leaf.am instead of leaf.cfg.
* 2001-09-13 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-09-132-16/+21
| | | | | * configure.in: autoupdate to autoconf-2.52, new CONFIG_SUBDIRS handling.
* 2001-08-16 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-08-162-2/+8
| | | | * include/tmacros.h: Attempt to print errno as further information.
* 2001-08-16 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-08-162-1/+5
| | | | * sp20/system.h: Account for extra task stacks properly.
* 2001-08-16 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-08-164-3/+8
| | | | | | * sp13/sp13.scn: Id in screen had wrong class field value. * sp13/system.h: Account for message buffer memory. * sp13/task2.c: Remove unnecessary check for failure.
* 2001-08-09 Fernando-Ruiz Casas <correo@fernando-ruiz.com>Joel Sherrill2001-08-093-9/+21
| | | | | | * psxchroot01/.cvsignore, psxchroot01/Makefile.am, psxchroot01/main.c, psxchroot01/psxchroot01.scn, psxchroot01/test.c: Implemented the psxchroot01 test.
* 2001-06-14 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-06-142-3/+5
| | | | | * cdtest/system.h: Removed configure of POSIX mutexes since there do not appear to be any used in this test.
* 2001-05-25 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-05-258-1/+211
| | | | | | | | * Added once version of psxchroot01 test for user review. * psxchroot01: New directory. * psxchroot01/Makefile.am, psxchroot01/main.c, psxchroot01/test.c, psxchroot01/psxchroot01.scn, psxchroot01/.cvsignore: New files. * configure.in, Makefile.am: Modified to reflect above.
* 2001-05-10 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-05-112-9/+5
| | | | | * configure.in: Remove RTEMS_PROG_CC_FOR_TARGET, RTEMS_PROG_CXX_FOR_TARGET, RTEMS_CANONICALIZE_TOOLS.
* 2001-05-10 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-05-1018-9/+45
| | | | * configure.in: Use RTEMS_PROG_CC_FOR_TARGET([-ansi -fasm]).
* 2001-04-24 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-04-243-0/+56
| | | | | | | * psxfile01/test.c, psxfile01/psxfile01.scn : Added test case for open, write, reopen, append twice from Andrew Bythell <abythell@nortelnetworks.com> that tripped an initialization problem in the IMFS.
* 2001-04-20 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-04-202-0/+7
| | | | | * sp298/sp28.scn: Minor adjustment so test output matches the screen file.
* 2001-04-20 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-04-2012-309/+306
| | | | | | | | * psx04/init.c, psx04/psx04.scn, psx07/init.c, psx07/psx07.scn, psxfile01/psxfile01.scn, psxmsgq01/psxmsgq01.scn, psxreaddir/test.c, psxstat/psxstat.scn, psxstat/test.c, psxtime/psxtime.scn, psxtimer/psxtimer.scn: Various adjustments so test output matches screens more reliably.
* 2001-04-20 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-04-205-6/+12
| | | | | | * itronmbf01/itronmbf01.scn, itronmbox01/init.c, itronsem01/itronsem01.scn, itrontime01/init.c: Various adjustments so test output matches screens more reliably.
* 2001-02-07 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-02-122-1/+5
| | | | * spsize/size.c: Use #if !defined(RTEMS_UNIX).
* 2001-01-26 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-01-2614-350/+11
| | | | | | | | | * configure.in: Remove stubdr, wrapup, AC_INIT(include). * Makefile.am: Remove stubdr, wrapup. * stubdr/Makefile.am, stubdr/open.c, stubdr/close.c, stubdr/init.c, stubdr/stubdrv.h, stubdr/cntrl.c, stubdr/.cvsignore, stubdr/read.c, stubdr/write.c, wrapup/Makefile.am, wrapup/.cvsignore, stubdr/, wrapup/: Remove.
