1998-03-24 | Rename hppa1_1 to hppa1.1 and switched to using __XXX__ macros for | Joel Sherrill | 2 | -9/+7 | |
the CPU family name constants. | |||||
1998-03-21 | Corrected typo in copyright notice. | Joel Sherrill | 1 | -1/+1 | |
1998-03-03 | Corrected to indicate test cases which were skipped. | Joel Sherrill | 1 | -2/+2 | |
1998-02-20 | Modified to reflect new restrictions on mutex being released. | Joel Sherrill | 1 | -1/+1 | |
1998-02-20 | Removed extra line. | Joel Sherrill | 1 | -1/+0 | |
1998-02-20 | Increased stack space to let test run to completion. | Joel Sherrill | 1 | -4/+4 | |
1998-02-19 | Increased stack space of tasks. | Joel Sherrill | 1 | -1/+1 | |
1998-02-19 | Increased stack size of initialization task. | Joel Sherrill | 1 | -0/+1 | |
1998-02-19 | Restructured so all times are placed in variables and printed in batch | Joel Sherrill | 1 | -163/+193 | |
mode at the end of the test. This eliminates the possibility of IO blocking a task unexpectedly and messing up the test. | |||||
1998-02-17 | updated copyright to 1998 | Joel Sherrill | 577 | -577/+577 | |
1998-02-17 | updated copyright to 1998 | Joel Sherrill | 1 | -1/+1 | |
1998-01-30 | Big patch form Ralf Corsepius described in this email: | Joel Sherrill | 141 | -564/+282 | |
Here is the result of my nightly work to get RTEMS_ROOT=$srcdir working with different shells and relative/absolute paths. What I did is relatively simple in principle: Instead of setting RTEMS_ROOT in configure.in and then let configure substitute @RTEMS_ROOT@ inside the Makefiles, I now let each Makefile set RTEMS_ROOT from each Makefile's @top_srcdir@ value. The difference is subtile, but with enormous side effects: - If RTEMS_ROOT is set in configure, then the same single value will be propagated to all Makefiles. This breaks using relative paths, as the relative path to the root of the source tree is used inside of all subdirectory Makefiles. - Now each Makefile.in sets RTEMS_ROOT = @top_srcdir@. top_srcdir is computed individually by configure for each single Makefile.in, hereby receiving the correct value, no matter if relative or absolute paths are used. To get this working, I needed to remove setting RTEMS_ROOT from target.cfg.in, because this overrides the value of RTEMS_ROOT from each individual Makefile. Furthermore, I removed RTEMS_CUSTOM from the Makefiles and replaced all "include $(RTEMS_CUSTOM)" directives with"include $(RTEMS_ROOT)/make/custom/$(RTEMS_BSP)". Perhaps you don't like this, but I think, to have one variable less is clearer and easier to understand than having several variables refering to the next one. I enclose a small patch to this mail, which - fixes the config.h problem (to finally clearify misunderstands) - removes assignment/subsitution of RTEMS_ROOT from configure.in - contains a workaround for the application Makefile's RTEMS_ROOT problem (reported by Eric) - removes some unused lines from the toplevel Makefile.in - removes assignment of RTEMS_ROOT from make/target.cfg.in | |||||
1998-01-23 | Solaris port updates from Chris Johns | Joel Sherrill | 2 | -0/+5 | |
1998-01-20 | Removed CONFIG_DIR and PROJECT_HOME directories. | Joel Sherrill | 141 | -141/+141 | |
1998-01-16 | Ralf Corsepius reported a number of missing CVS Id's: | Joel Sherrill | 12 | -10/+14 | |
> RTEMS is under CVS control and has been since rtems 3.1.16 which was > around May 1995. So I just to add the $Id$. If you notice other files > with missing $Id$'s let me know. I try to keep w\up with it. Now that you have asked -- I'll attach a list of files lacking an RCS-Id to this mail. This list has been generated by a little sh-script I'll also enclose. | |||||
1997-12-10 | Modified a lot of files to take a first cut at supporting building from | Joel Sherrill | 141 | -141/+564 | |
any directory in the build tree. The only variable which must be set before the command "gmake" is invoked is RTEMS_BSP (e.g. RTEMS_BSP=erc32). | |||||
1997-11-30 | Since test suite Makefiles are not always generated, use wildcard | Joel Sherrill | 1 | -4/+3 | |
to determine which directories to descend into. | |||||
1997-11-18 | Removed warning. | Joel Sherrill | 1 | -1/+1 | |
1997-11-18 | New file. | Joel Sherrill | 1 | -0/+45 | |
1997-10-23 | Added new test for termios style consoles from Eric Norum. | Joel Sherrill | 3 | -1/+205 | |
1997-10-21 | Added test case for rtems_interrupt_catch checking that the pointer | Joel Sherrill | 2 | -1/+11 | |
for the returned old_isr_handler was non-NULL. | |||||
1997-10-09 | Fixed some spacing. | Joel Sherrill | 2 | -4/+4 | |
1997-10-08 | Fix from Eric Norum so FPSP is installed before any FP code is actually | Joel Sherrill | 1 | -0/+9 | |
exercise. | |||||
1997-10-08 | Fixed typo in the pointer to the license terms. | Joel Sherrill | 579 | -1158/+1158 | |
1997-10-08 | Removed include directory at "build" point and the link of this directory | Joel Sherrill | 4 | -7/+7 | |
to lib/include. Went to using a PROJECT_INCLUDE variable. | |||||
1997-10-06 | Fixed some weird line duplications. Thanks to Chris Johns. | Joel Sherrill | 1 | -18/+9 | |
1997-09-21 | Added Monitor test. | Joel Sherrill | 4 | -1/+192 | |
1997-08-27 | Corrected reference to LIBC_LIBM to work on all targets. | Joel Sherrill | 1 | -1/+1 | |
1997-08-26 | Patches from Chris Johns to clean up test. | Joel Sherrill | 5 | -19/+52 | |
1997-08-26 | removed -lm | Joel Sherrill | 1 | -1/+1 | |
1997-07-31 | Merged very large and much appreciated patch from Chris Johns | Joel Sherrill | 8 | -0/+1274 | |
<cjohns@plessey.com.au>. This patch includes the ods68302 bsp, the RTEMS++ class library, and the rtems++ test. | |||||
1997-07-31 | Merged very large and much appreciated patch from Chris Johns | Joel Sherrill | 3 | -2/+12 | |
1997-07-31 | Added support for rtems_message_queue_get_number_pending. | Joel Sherrill | 4 | -0/+21 | |
1997-07-09 | Used macro instead of hard coded number. | Joel Sherrill | 1 | -1/+1 | |
1997-04-22 | incorrect screen name for multiprocessing tests. | Joel Sherrill | 1 | -1/+1 | |
1997-04-22 | updated with new license information per Tony Bennett. | Joel Sherrill | 1 | -13/+5 | |
1997-04-22 | headers updated to reflect new style copyright notice as part | Joel Sherrill | 571 | -2855/+2855 | |
of switching to the modified GNU GPL. | |||||
1997-04-18 | Modified to reflect change from 255 posix priority levels to 254. | Joel Sherrill | 3 | -6/+6 | |
1997-04-18 | Corrected incorrect settings for locations of psx and sp test screens. | Joel Sherrill | 1 | -2/+2 | |
1997-04-15 | Added line to install test screens so difftest does not have to have | Joel Sherrill | 65 | -7/+137 | |
a path back into the source tree. This would be better for binary distributions as well since you now have the correct output at the install point. | |||||
1997-04-09 | enabled floating point and fixed confdef reference to initialization | Joel Sherrill | 4 | -5/+9 | |
tasks table. | |||||
1997-04-09 | new test | Joel Sherrill | 14 | -0/+862 | |
1997-04-09 | added cpuuse and rtmonuse | Joel Sherrill | 1 | -1/+1 | |
1997-04-07 | corrected printf specifications and added casts as necessary to eliminate | Joel Sherrill | 7 | -72/+79 | |
warnings. | |||||
1997-04-07 | added ifdef to avoid warning for unused variable. | Joel Sherrill | 1 | -2/+6 | |
1997-04-07 | corrected integer only definitions of "FP CHECK" routines to eliminate | Joel Sherrill | 1 | -3/+10 | |
warnings. | |||||
1997-04-02 | corrected one of the references to an environment variable which | Joel Sherrill | 1 | -1/+1 | |
is no longer used since autoconf is in place. | |||||
1997-04-02 | corrected printf format to avoid warning | Joel Sherrill | 7 | -11/+11 | |
1997-04-02 | initialized variables or removed unused variables to remove warnings | Joel Sherrill | 3 | -4/+3 | |
1997-04-01 | This set of changes is the build of what was required to convert to | Joel Sherrill | 136 | -0/+6948 | |
GNU autoconf. This is the first large step in allowing an RTEMS user to perform a one-tree build (per crossgcc FAQ) including RTEMS in the build process. With this change RTEMS is configured in built in the same style as the GNU tools, yet retains the basic structure of its traditional Makefiles (ala Tony Bennett). Jiri Gaisler (jgais@wd.estec.esa.nl) deserves (and received) a big thank you for doing this. There are still issues to be resolved but as of this commit, all target which can be built on a linux host have been using a modified version of the source Jiri submitted. This source was merged and most targets built in the tree before this commit. There are some issues which remain to be resolved but they are primarily related to host OS dependencies, script issues, the use of gawk for hack_specs, and the dependence on gcc snapshots. These will be resolved. |
