* | new file | Joel Sherrill | 1996-05-24 | 14 | -0/+337 |
* | new file | Joel Sherrill | 1996-05-24 | 1 | -0/+50 |
* | updates from Tony Bennett to correct calling sequences. | Joel Sherrill | 1996-05-24 | 2 | -0/+2 |
* | new files | Joel Sherrill | 1996-05-24 | 3 | -4/+111 |
* | new file | Mark Johannes | 1996-05-24 | 1 | -0/+22 |
* | added use of sporadic server scheduling parameters | Joel Sherrill | 1996-05-24 | 7 | -0/+58 |
* | new files | Joel Sherrill | 1996-05-24 | 3 | -0/+96 |
* | clean up on DELAYTIMER_MAX | Joel Sherrill | 1996-05-23 | 3 | -12/+0 |
* | new files | Joel Sherrill | 1996-05-23 | 6 | -0/+204 |
* | unused variable | Joel Sherrill | 1996-05-23 | 1 | -1/+0 |
* | new files | Joel Sherrill | 1996-05-23 | 8 | -0/+208 |
* | new files | Joel Sherrill | 1996-05-23 | 7 | -0/+184 |
* | new files | Joel Sherrill | 1996-05-23 | 3 | -0/+75 |
* | new files | Joel Sherrill | 1996-05-23 | 5 | -0/+144 |
* | new files | Joel Sherrill | 1996-05-23 | 4 | -0/+110 |
* | cleanup | Joel Sherrill | 1996-05-23 | 8 | -12/+12 |
* | new files | Joel Sherrill | 1996-05-23 | 8 | -0/+254 |
* | cleanup status vs. result | Joel Sherrill | 1996-05-23 | 29 | -48/+48 |
* | new files | Joel Sherrill | 1996-05-23 | 5 | -0/+152 |
* | new files | Joel Sherrill | 1996-05-23 | 4 | -0/+134 |
* | new files | Joel Sherrill | 1996-05-23 | 2 | -0/+60 |
* | new files | Joel Sherrill | 1996-05-23 | 6 | -0/+200 |
* | new files | Joel Sherrill | 1996-05-23 | 9 | -0/+288 |
* | updated to reflect more constants and feature macros | Joel Sherrill | 1996-05-23 | 34 | -5/+160 |
* | updates from Tony Bennett | Joel Sherrill | 1996-05-23 | 2 | -1/+16 |
* | created posix test suite with test of header files | Joel Sherrill | 1996-05-22 | 51 | -0/+1379 |
* | added posix test directory | Joel Sherrill | 1996-05-10 | 1 | -3/+8 |
* | Lowered number of messages created to reduce burden on workspace. | Joel Sherrill | 1996-04-22 | 1 | -1/+1 |
* | updates from Tony Bennett | Joel Sherrill | 1996-04-22 | 4 | -5/+7 |
* | addition of optional user provided stack allocator means that we can not | Joel Sherrill | 1996-04-22 | 1 | -14/+27 |
| | | | | | reliably produce the "insufficient memory for stack space" error if this extension is configured. | ||||
* | As part of reducing visibility into rtems and hiding the .inl files | Joel Sherrill | 1996-03-06 | 1 | -0/+1 |
| | | | | | from the application code, this file required more visibility than is given by default to application code. | ||||
* | The name of the test support routine pause was changed to rtems_test_pause | Joel Sherrill | 1996-02-22 | 13 | -42/+38 |
| | | | | to avoid conflict with the standard POSIX routine pause(2). | ||||
* | Dispersal of internal thread handler resulted in removal of some | Joel Sherrill | 1996-02-21 | 1 | -16/+11 |
| | | | | variables and renaming of others. | ||||
* | removed post switch extension | Joel Sherrill | 1996-02-13 | 3 | -3/+0 |
* | As part of implementing the new isr synchronization algorithm using a | Joel Sherrill | 1996-02-09 | 1 | -1/+1 |
| | | | | single enumerated set of states the set of event manager variables changed. | ||||
* | Added RTEMS API control structure to per task memory usage macro. | Joel Sherrill | 1996-01-19 | 1 | -1/+2 |
* | Increased stack size. | Joel Sherrill | 1996-01-19 | 3 | -3/+5 |
* | increased stack space | Joel Sherrill | 1996-01-17 | 2 | -2/+2 |
* | Init task was not defined as being floating point. | Joel Sherrill | 1996-01-15 | 1 | -0/+2 |
* | updates from Tony Bennett for PA and UNIX ports | Joel Sherrill | 1996-01-15 | 4 | -11/+16 |
* | changes remerged after lost in disk crash -- recovered from snapshot, ↵ | Joel Sherrill | 1995-12-20 | 31 | -113/+230 |
| | | | | partially recovered working tree, etc | ||||
* | changes remerged after disk crash -- history lost | Joel Sherrill | 1995-12-19 | 3 | -121/+0 |
* | file lost in crash and re-added | Joel Sherrill | 1995-12-19 | 1 | -0/+192 |
* | typos fixed | Joel Sherrill | 1995-10-31 | 1 | -0/+5 |
* | SPARC port passes all tests | Joel Sherrill | 1995-10-30 | 12 | -30/+84 |
* | reordered test cases from simple to complex | Joel Sherrill | 1995-10-11 | 1 | -13/+25 |
* | fixed missing CVS IDs | Joel Sherrill | 1995-10-06 | 6 | -5/+7 |
* | all targets compile .. tony's patches in place | Joel Sherrill | 1995-09-29 | 2 | -5/+1 |
* | Modified UNIX simulator port so all references to native unix | Joel Sherrill | 1995-09-27 | 8 | -24/+24 |
| | | | | | stuff is in the executive source proper in the file cpu.c. This should help avoid conflicts between RTEMS POSIX files and UNIX files. | ||||
* | posix support initially added | Joel Sherrill | 1995-09-26 | 1 | -10/+10 |
