1997-04-22 | incorrect screen name for multiprocessing tests. | Joel Sherrill | 1 | -1/+1 | |
1997-04-22 | updated with new license information per Tony Bennett. | Joel Sherrill | 1 | -13/+5 | |
1997-04-22 | headers updated to reflect new style copyright notice as part | Joel Sherrill | 571 | -2855/+2855 | |
of switching to the modified GNU GPL. | |||||
1997-04-18 | Modified to reflect change from 255 posix priority levels to 254. | Joel Sherrill | 3 | -6/+6 | |
1997-04-18 | Corrected incorrect settings for locations of psx and sp test screens. | Joel Sherrill | 1 | -2/+2 | |
1997-04-15 | Added line to install test screens so difftest does not have to have | Joel Sherrill | 65 | -7/+137 | |
a path back into the source tree. This would be better for binary distributions as well since you now have the correct output at the install point. | |||||
1997-04-09 | enabled floating point and fixed confdef reference to initialization | Joel Sherrill | 4 | -5/+9 | |
tasks table. | |||||
1997-04-09 | new test | Joel Sherrill | 14 | -0/+862 | |
1997-04-09 | added cpuuse and rtmonuse | Joel Sherrill | 1 | -1/+1 | |
1997-04-07 | corrected printf specifications and added casts as necessary to eliminate | Joel Sherrill | 7 | -72/+79 | |
warnings. | |||||
1997-04-07 | added ifdef to avoid warning for unused variable. | Joel Sherrill | 1 | -2/+6 | |
1997-04-07 | corrected integer only definitions of "FP CHECK" routines to eliminate | Joel Sherrill | 1 | -3/+10 | |
warnings. | |||||
1997-04-02 | corrected one of the references to an environment variable which | Joel Sherrill | 1 | -1/+1 | |
is no longer used since autoconf is in place. | |||||
1997-04-02 | corrected printf format to avoid warning | Joel Sherrill | 7 | -11/+11 | |
1997-04-02 | initialized variables or removed unused variables to remove warnings | Joel Sherrill | 3 | -4/+3 | |
1997-04-01 | This set of changes is the build of what was required to convert to | Joel Sherrill | 136 | -0/+6948 | |
GNU autoconf. This is the first large step in allowing an RTEMS user to perform a one-tree build (per crossgcc FAQ) including RTEMS in the build process. With this change RTEMS is configured in built in the same style as the GNU tools, yet retains the basic structure of its traditional Makefiles (ala Tony Bennett). Jiri Gaisler (jgais@wd.estec.esa.nl) deserves (and received) a big thank you for doing this. There are still issues to be resolved but as of this commit, all target which can be built on a linux host have been using a modified version of the source Jiri submitted. This source was merged and most targets built in the tree before this commit. There are some issues which remain to be resolved but they are primarily related to host OS dependencies, script issues, the use of gawk for hack_specs, and the dependence on gcc snapshots. These will be resolved. | |||||
1997-03-08 | added support for posix tests | Joel Sherrill | 1 | -1/+3 | |
1997-01-29 | Made stopping for the pause an option which can be configured in the | Joel Sherrill | 1 | -0/+12 | |
targopts.h file. | |||||
1997-01-08 | _CPU_Trap_Table_area is now conditional based on whether or not | Joel Sherrill | 1 | -2/+5 | |
the application requires rtems to allocate a trap table | |||||
1996-09-18 | new files | Joel Sherrill | 3 | -0/+205 | |
1996-09-18 | added cast | Joel Sherrill | 1 | -1/+1 | |
1996-09-18 | address arithmetic changed to be more portable | Joel Sherrill | 1 | -3/+7 | |
1996-09-18 | new test submitted by Craig Lebakken (lebakken@minn.net) and Derrick Ostertag | Joel Sherrill | 3 | -0/+230 | |
(ostertag@transition.com) | |||||
1996-09-17 | extended Task_id and Task_name arrays to avoid indexing past end of array. | Joel Sherrill | 1 | -2/+2 | |
1996-09-12 | Fixed test to match change to pthread_cond_timedwait which now takes a wall | Mark Johannes | 1 | -26/+32 | |
time. Commented out calls to pthread_cond_wait and pthread_cond_timedwait without the mutex locked before calling. | |||||
1996-09-06 | modified test to take into account change in default value of | Joel Sherrill | 1 | -0/+5 | |
inheritsched pthread attribute from implicit to explicit scheduling parameters. | |||||
1996-09-05 | added printf of status when not successful | Joel Sherrill | 1 | -1/+3 | |
1996-09-05 | nanosleep no longer consider a negative value of tv_sec to be an error. | Joel Sherrill | 1 | -6/+7 | |
Instead it is an indication of a request for a small delay. | |||||
1996-08-23 | Changed all EFAULTS to EINVALs | Mark Johannes | 1 | -14/+20 | |
1996-08-23 | filled in screen | Mark Johannes | 1 | -0/+11 | |
1996-08-23 | Filled in screen | Mark Johannes | 2 | -0/+78 | |
1996-08-23 | Filled in the screen | Mark Johannes | 9 | -0/+479 | |
1996-08-23 | Added build_time statement to provide a tm for the test | Mark Johannes | 1 | -2/+4 | |
1996-08-23 | Changed test 5 to test 10 at bottom | Mark Johannes | 1 | -1/+1 | |
1996-08-22 | Commented out the EINVAL for mutex not acquired befor cond_wait call | Mark Johannes | 1 | -4/+9 | |
1996-08-21 | updated to support ENOTSUP | Mark Johannes | 1 | -10/+10 | |
1996-08-20 | Added Einval case for mutex not initialized | Mark Johannes | 1 | -0/+10 | |
1996-08-15 | init: added tests for pthread_kill and kill errors. | Mark Johannes | 1 | -32/+186 | |
1996-08-15 | changed error code | Joel Sherrill | 1 | -2/+2 | |
1996-08-15 | changed error for too many threads to EAGAIN | Joel Sherrill | 1 | -2/+2 | |
1996-08-14 | pthread_mutex_init returns EAGAIN not ENOMEM when there are too many mutexes. | Joel Sherrill | 1 | -2/+2 | |
1996-08-14 | added test cases for NULL being passed to pthread attribute get routines | Joel Sherrill | 1 | -0/+20 | |
1996-08-14 | added test case for pthread_attr_getscope being passed a NULL contentionscope | Joel Sherrill | 1 | -0/+4 | |
1996-08-14 | system.h: added task3 and changed condition variable config to 1 | Mark Johannes | 1 | -1/+6 | |
1996-08-14 | task3: added to test error case in Wait_support for lock on mutex | Mark Johannes | 1 | -0/+46 | |
1996-08-14 | init: added error case for wait timedwait, and wait support | Mark Johannes | 1 | -8/+153 | |
1996-08-14 | pthread_attr_setscope: returns ENOTSUP not ENOSYS for unsupport scope | Joel Sherrill | 1 | -2/+2 | |
1996-08-13 | task_2: added comments and print statement for task exit | Mark Johannes | 1 | -0/+1 | |
1996-08-13 | task_1: added comments and print statement for task exit | Mark Johannes | 1 | -0/+5 | |
1996-08-13 | Init.c: added timewait case, added broadcast case | Mark Johannes | 1 | -3/+28 | |
