* tm20/Makefile.am: Remove stubdir.rel
* tmtests.am: Remove DEFS.
* tm01/Makefile.am, tm02/Makefile.am, tm03/Makefile.am,
tm04/Makefile.am, tm05/Makefile.am, tm06/Makefile.am,
tm07/Makefile.am, tm08/Makefile.am, tm09/Makefile.am,
tm10/Makefile.am, tm11/Makefile.am, tm12/Makefile.am,
tm13/Makefile.am, tm14/Makefile.am, tm15/Makefile.am,
tm16/Makefile.am, tm17/Makefile.am, tm18/Makefile.am,
tm19/Makefile.am, tm20/Makefile.am, tm21/Makefile.am,
tm22/Makefile.am, tm23/Makefile.am, tm24/Makefile.am,
tm25/Makefile.am, tm26/Makefile.am, tm27/Makefile.am,
tm28/Makefile.am, tm29/Makefile.am, tmck/Makefile.am,
tmoverhd/Makefile.am: Include compile.am
cpuopts.h.
exec/configure.in, only.
quoting bugs in autoconf).
formating changes :)
that contains:
* Removes MKLIB
handling)
RTEMS_TM27 is defined before the bsp.h is included.
too small when OPERATION_COUNT is less than 10.
Addtional major bugs:
<corsepiu@faw.uni-ulm.de>.
to convert the tmtests directory from Makefile.in to Makefile.am.
<corsepiu@faw.uni-ulm.de> which turns OPERATION_COUNT into a configure
time option.
which allow the BSP to override the default number of objects
that will be created in the timing tests. This is useful for
reducing memory consumption on small targets. The BSP_ITERATION_COUNT
can be used to reduce the number of repititions in some of the
tests. This is useful for extremely slow targets (we haven't seen
any slow enough to justify modifying this one yet though. :)
was unnecessary. The real fix was an alignment error in the
object extend memory allocation scheme.
dependencies of "Makefile".
--enable-maintainer-mode.
future.
cd <rtems-source-tree>
this week until now.
It consists of 3 parts:
1. a patch
2. a perl script (acpolish)
plural).
configure scripts etc.
added by acpolish.
To apply this:
./rtems-polish.sh
Later:
cvs add contrib
cvs add contrib/acpolish
cvs commit
more accurate.
mode at the end of the test. This eliminates the possibility of IO
blocking a task unexpectedly and messing up the test.
subdirectory Makefiles.
used.
individual Makefile.
problem (reported by Eric)
