path: root/c/src/tests/tmtests/tmoverhd/Makefile.am (unfollow)
2003-11-112003-11-10 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius1-45/+0
* include/.cvsignore: Remove. * include/Makefile.am: Remove. * include/timesys.h: Remove. * .cvsignore: Remove. * ChangeLog: Remove. * Makefile.am: Remove. * README: Remove. * configure.ac: Remove. * tmtests.am: Remove. * tm01/.cvsignore: Remove. * tm01/Makefile.am: Remove. * tm01/system.h: Remove. * tm01/task1.c: Remove. * tm01/tm01.doc: Remove. * tm02/.cvsignore: Remove. * tm02/Makefile.am: Remove. * tm02/system.h: Remove. * tm02/task1.c: Remove. * tm02/tm02.doc: Remove. * tm03/.cvsignore: Remove. * tm03/Makefile.am: Remove. * tm03/system.h: Remove. * tm03/task1.c: Remove. * tm03/tm03.doc: Remove. * tm04/.cvsignore: Remove. * tm04/Makefile.am: Remove. * tm04/system.h: Remove. * tm04/task1.c: Remove. * tm04/tm04.doc: Remove. * tm05/.cvsignore: Remove. * tm05/Makefile.am: Remove. * tm05/system.h: Remove. * tm05/task1.c: Remove. * tm05/tm05.doc: Remove. * tm06/.cvsignore: Remove. * tm06/Makefile.am: Remove. * tm06/system.h: Remove. * tm06/task1.c: Remove. * tm06/tm06.doc: Remove. * tm07/.cvsignore: Remove. * tm07/Makefile.am: Remove. * tm07/system.h: Remove. * tm07/task1.c: Remove. * tm07/tm07.doc: Remove. * tm08/.cvsignore: Remove. * tm08/Makefile.am: Remove. * tm08/system.h: Remove. * tm08/task1.c: Remove. * tm08/tm08.doc: Remove. * tm09/.cvsignore: Remove. * tm09/Makefile.am: Remove. * tm09/system.h: Remove. * tm09/task1.c: Remove. * tm09/tm09.doc: Remove. * tm10/.cvsignore: Remove. * tm10/Makefile.am: Remove. * tm10/system.h: Remove. * tm10/task1.c: Remove. * tm10/tm10.doc: Remove. * tm11/.cvsignore: Remove. * tm11/Makefile.am: Remove. * tm11/system.h: Remove. * tm11/task1.c: Remove. * tm11/tm11.doc: Remove. * tm12/.cvsignore: Remove. * tm12/Makefile.am: Remove. * tm12/system.h: Remove. * tm12/task1.c: Remove. * tm12/tm12.doc: Remove. * tm13/.cvsignore: Remove. * tm13/Makefile.am: Remove. * tm13/system.h: Remove. * tm13/task1.c: Remove. * tm13/tm13.doc: Remove. * tm14/.cvsignore: Remove. * tm14/Makefile.am: Remove. * tm14/system.h: Remove. * tm14/task1.c: Remove. * tm14/tm14.doc: Remove. * tm15/.cvsignore: Remove. * tm15/Makefile.am: Remove. * tm15/system.h: Remove. * tm15/task1.c: Remove. * tm15/tm15.doc: Remove. * tm16/.cvsignore: Remove. * tm16/Makefile.am: Remove. * tm16/system.h: Remove. * tm16/task1.c: Remove. * tm16/tm16.doc: Remove. * tm17/.cvsignore: Remove. * tm17/Makefile.am: Remove. * tm17/system.h: Remove. * tm17/task1.c: Remove. * tm17/tm17.doc: Remove. * tm18/.cvsignore: Remove. * tm18/Makefile.am: Remove. * tm18/system.h: Remove. * tm18/task1.c: Remove. * tm18/tm18.doc: Remove. * tm19/.cvsignore: Remove. * tm19/Makefile.am: Remove. * tm19/system.h: Remove. * tm19/task1.c: Remove. * tm19/tm19.doc: Remove. * tm20/.cvsignore: Remove. * tm20/Makefile.am: Remove. * tm20/system.h: Remove. * tm20/task1.c: Remove. * tm20/tm20.doc: Remove. * tm21/.cvsignore: Remove. * tm21/Makefile.am: Remove. * tm21/system.h: Remove. * tm21/task1.c: Remove. * tm21/tm21.doc: Remove. * tm22/.cvsignore: Remove. * tm22/Makefile.am: Remove. * tm22/system.h: Remove. * tm22/task1.c: Remove. * tm22/tm22.doc: Remove. * tm23/.cvsignore: Remove. * tm23/Makefile.am: Remove. * tm23/system.h: Remove. * tm23/task1.c: Remove. * tm23/tm23.doc: Remove. * tm24/.cvsignore: Remove. * tm24/Makefile.am: Remove. * tm24/system.h: Remove. * tm24/task1.c: Remove. * tm24/tm24.doc: Remove. * tm25/.cvsignore: Remove. * tm25/Makefile.am: Remove. * tm25/system.h: Remove. * tm25/task1.c: Remove. * tm25/tm25.doc: Remove. * tm26/.cvsignore: Remove. * tm26/Makefile.am: Remove. * tm26/fptest.h: Remove. * tm26/system.h: Remove. * tm26/task1.c: Remove. * tm26/tm26.doc: Remove. * tm27/.cvsignore: Remove. * tm27/Makefile.am: Remove. * tm27/system.h: Remove. * tm27/task1.c: Remove. * tm27/tm27.doc: Remove. * tm28/.cvsignore: Remove. * tm28/Makefile.am: Remove. * tm28/system.h: Remove. * tm28/task1.c: Remove. * tm28/tm28.doc: Remove. * tm29/.cvsignore: Remove. * tm29/Makefile.am: Remove. * tm29/system.h: Remove. * tm29/task1.c: Remove. * tm29/tm29.doc: Remove. * tmck/.cvsignore: Remove. * tmck/Makefile.am: Remove. * tmck/system.h: Remove. * tmck/task1.c: Remove. * tmck/tmck.doc: Remove. * tmoverhd/.cvsignore: Remove. * tmoverhd/Makefile.am: Remove. * tmoverhd/dumrtems.h: Remove. * tmoverhd/empty.c: Remove. * tmoverhd/system.h: Remove. * tmoverhd/testtask.c: Remove. * tmoverhd/tmoverhd.doc: Remove.
2003-08-162003-08-16 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius1-3/+3
Makefile.am: Reflect having moved automake. include/Makefile.am: Reflect having moved automake. tm01/Makefile.am: Reflect having moved automake. tm02/Makefile.am: Reflect having moved automake. tm03/Makefile.am: Reflect having moved automake. tm04/Makefile.am: Reflect having moved automake. tm05/Makefile.am: Reflect having moved automake. tm06/Makefile.am: Reflect having moved automake. tm07/Makefile.am: Reflect having moved automake. tm08/Makefile.am: Reflect having moved automake. tm09/Makefile.am: Reflect having moved automake. tm10/Makefile.am: Reflect having moved automake. tm11/Makefile.am: Reflect having moved automake. tm12/Makefile.am: Reflect having moved automake. tm13/Makefile.am: Reflect having moved automake. tm14/Makefile.am: Reflect having moved automake. tm15/Makefile.am: Reflect having moved automake. tm16/Makefile.am: Reflect having moved automake. tm17/Makefile.am: Reflect having moved automake. tm18/Makefile.am: Reflect having moved automake. tm19/Makefile.am: Reflect having moved automake. tm20/Makefile.am: Reflect having moved automake. tm21/Makefile.am: Reflect having moved automake. tm22/Makefile.am: Reflect having moved automake. tm23/Makefile.am: Reflect having moved automake. tm24/Makefile.am: Reflect having moved automake. tm25/Makefile.am: Reflect having moved automake. tm26/Makefile.am: Reflect having moved automake. tm27/Makefile.am: Reflect having moved automake. tm28/Makefile.am: Reflect having moved automake. tm29/Makefile.am: Reflect having moved automake. tmck/Makefile.am: Reflect having moved automake. tmoverhd/Makefile.am: Reflect having moved automake.
2002-08-112002-08-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius1-1/+1
* tm01/Makefile.am: Use $(OBJEXT) instead of .o. * tm02/Makefile.am: Use $(OBJEXT) instead of .o. * tm03/Makefile.am: Use $(OBJEXT) instead of .o. * tm04/Makefile.am: Use $(OBJEXT) instead of .o. * tm05/Makefile.am: Use $(OBJEXT) instead of .o. * tm06/Makefile.am: Use $(OBJEXT) instead of .o. * tm07/Makefile.am: Use $(OBJEXT) instead of .o. * tm08/Makefile.am: Use $(OBJEXT) instead of .o. * tm09/Makefile.am: Use $(OBJEXT) instead of .o. * tm10/Makefile.am: Use $(OBJEXT) instead of .o. * tm11/Makefile.am: Use $(OBJEXT) instead of .o. * tm12/Makefile.am: Use $(OBJEXT) instead of .o. * tm13/Makefile.am: Use $(OBJEXT) instead of .o. * tm14/Makefile.am: Use $(OBJEXT) instead of .o. * tm15/Makefile.am: Use $(OBJEXT) instead of .o. * tm16/Makefile.am: Use $(OBJEXT) instead of .o. * tm17/Makefile.am: Use $(OBJEXT) instead of .o. * tm18/Makefile.am: Use $(OBJEXT) instead of .o. * tm19/Makefile.am: Use $(OBJEXT) instead of .o. * tm20/Makefile.am: Use $(OBJEXT) instead of .o. * tm21/Makefile.am: Use $(OBJEXT) instead of .o. * tm22/Makefile.am: Use $(OBJEXT) instead of .o. * tm23/Makefile.am: Use $(OBJEXT) instead of .o. * tm24/Makefile.am: Use $(OBJEXT) instead of .o. * tm25/Makefile.am: Use $(OBJEXT) instead of .o. * tm26/Makefile.am: Use $(OBJEXT) instead of .o. * tm27/Makefile.am: Use $(OBJEXT) instead of .o. * tm28/Makefile.am: Use $(OBJEXT) instead of .o. * tm29/Makefile.am: Use $(OBJEXT) instead of .o. * tmck/Makefile.am: Use $(OBJEXT) instead of .o. * tmoverhd/Makefile.am: Use $(OBJEXT) instead of .o.
2002-03-282002-03-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1-1/+0
* configure.ac: AC_INIT(package,_RTEMS_VERSION,_RTEMS_BUGS). AM_INIT_AUTOMAKE([no-define foreign 1.6]). * include/Makefile.am: Remove AUTOMAKE_OPTIONS. * Makefile.am: Remove AUTOMAKE_OPTIONS. * tm01/Makefile.am: Remove AUTOMAKE_OPTIONS. * tm02/Makefile.am: Remove AUTOMAKE_OPTIONS. * tm03/Makefile.am: Remove AUTOMAKE_OPTIONS. * tm04/Makefile.am: Remove AUTOMAKE_OPTIONS. * tm05/Makefile.am: Remove AUTOMAKE_OPTIONS. * tm06/Makefile.am: Remove AUTOMAKE_OPTIONS. * tm07/Makefile.am: Remove AUTOMAKE_OPTIONS. * tm08/Makefile.am: Remove AUTOMAKE_OPTIONS. * tm09/Makefile.am: Remove AUTOMAKE_OPTIONS. * tm10/Makefile.am: Remove AUTOMAKE_OPTIONS. * tm11/Makefile.am: Remove AUTOMAKE_OPTIONS. * tm12/Makefile.am: Remove AUTOMAKE_OPTIONS. * tm13/Makefile.am: Remove AUTOMAKE_OPTIONS. * tm14/Makefile.am: Remove AUTOMAKE_OPTIONS. * tm15/Makefile.am: Remove AUTOMAKE_OPTIONS. * tm16/Makefile.am: Remove AUTOMAKE_OPTIONS. * tm17/Makefile.am: Remove AUTOMAKE_OPTIONS. * tm18/Makefile.am: Remove AUTOMAKE_OPTIONS. * tm19/Makefile.am: Remove AUTOMAKE_OPTIONS. * tm20/Makefile.am: Remove AUTOMAKE_OPTIONS. * tm21/Makefile.am: Remove AUTOMAKE_OPTIONS. * tm22/Makefile.am: Remove AUTOMAKE_OPTIONS. * tm23/Makefile.am: Remove AUTOMAKE_OPTIONS. * tm24/Makefile.am: Remove AUTOMAKE_OPTIONS. * tm25/Makefile.am: Remove AUTOMAKE_OPTIONS. * tm26/Makefile.am: Remove AUTOMAKE_OPTIONS. * tm27/Makefile.am: Remove AUTOMAKE_OPTIONS. * tm28/Makefile.am: Remove AUTOMAKE_OPTIONS. * tm29/Makefile.am: Remove AUTOMAKE_OPTIONS. * tmck/Makefile.am: Remove AUTOMAKE_OPTIONS. * tmoverhd/Makefile.am: Remove AUTOMAKE_OPTIONS.
2001-09-192001-09-19 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1-1/+1
* tm27/Makefile.am: include leaf.am instead of leaf.cfg. * tm26/Makefile.am: include leaf.am instead of leaf.cfg. * tm24/Makefile.am: include leaf.am instead of leaf.cfg. * tm16/Makefile.am: include leaf.am instead of leaf.cfg. * tm18/Makefile.am: include leaf.am instead of leaf.cfg. * tm02/Makefile.am: include leaf.am instead of leaf.cfg. * tm10/Makefile.am: include leaf.am instead of leaf.cfg. * tm11/Makefile.am: include leaf.am instead of leaf.cfg. * tm15/Makefile.am: include leaf.am instead of leaf.cfg. * tm19/Makefile.am: include leaf.am instead of leaf.cfg. * tm04/Makefile.am: include leaf.am instead of leaf.cfg. * tm17/Makefile.am: include leaf.am instead of leaf.cfg. * tm28/Makefile.am: include leaf.am instead of leaf.cfg. * tmck/Makefile.am: include leaf.am instead of leaf.cfg. * tm08/Makefile.am: include leaf.am instead of leaf.cfg. * tm12/Makefile.am: include leaf.am instead of leaf.cfg. * tm03/Makefile.am: include leaf.am instead of leaf.cfg. * tm13/Makefile.am: include leaf.am instead of leaf.cfg. * tm29/Makefile.am: include leaf.am instead of leaf.cfg. * tmoverhd/Makefile.am: include leaf.am instead of leaf.cfg. * tm20/Makefile.am: include leaf.am instead of leaf.cfg. * tm09/Makefile.am: include leaf.am instead of leaf.cfg. * tm01/Makefile.am: include leaf.am instead of leaf.cfg. * tm21/Makefile.am: include leaf.am instead of leaf.cfg. * tm07/Makefile.am: include leaf.am instead of leaf.cfg. * tm25/Makefile.am: include leaf.am instead of leaf.cfg. * tm22/Makefile.am: include leaf.am instead of leaf.cfg. * tm06/Makefile.am: include leaf.am instead of leaf.cfg. * tm05/Makefile.am: include leaf.am instead of leaf.cfg. * tm14/Makefile.am: include leaf.am instead of leaf.cfg. * tm23/Makefile.am: include leaf.am instead of leaf.cfg.
2000-09-052000-09-04 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1-0/+1
* tm01/Makefile.am, tm02/Makefile.am, tm03/Makefile.am, tm04/Makefile.am, tm05/Makefile.am, tm06/Makefile.am, tm07/Makefile.am, tm08/Makefile.am, tm09/Makefile.am, tm10/Makefile.am, tm11/Makefile.am, tm12/Makefile.am, tm13/Makefile.am, tm14/Makefile.am, tm15/Makefile.am, tm16/Makefile.am, tm17/Makefile.am, tm18/Makefile.am, tm19/Makefile.am, tm20/Makefile.am, tm21/Makefile.am, tm22/Makefile.am, tm23/Makefile.am, tm24/Makefile.am, tm25/Makefile.am, tm26/Makefile.am, tm27/Makefile.am, tm28/Makefile.am, tm29/Makefile.am, tmck/Makefile.am, tmoverhd/Makefile.am: Include compile.am
2000-06-12Merged from 4.5.0-beta3aJoel Sherrill1-3/+4
2000-01-31Patch rtems-rc-20000118-2.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1-1/+0
that contains cosmetical changes to the Makefile.ams below tests (removes old, now invalid comments from these Makefile.ams).
1999-11-23Patch rtems-rc-19991117-12.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1-8/+12
to convert the tmtests directory from Makefile.in to Makefile.am.
1999-11-22Patch rtems-rc-19991117-8.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1-1/+2
1999-11-22Converted to automake.Joel Sherrill1-0/+40
