to convert the tmtests directory from Makefile.in to Makefile.am.
<corsepiu@faw.uni-ulm.de> which turns OPERATION_COUNT into a configure
time option.
was unnecessary. The real fix was an alignment error in the
object extend memory allocation scheme.
dependencies of "Makefile".
--enable-maintainer-mode.
future.
cd <rtems-source-tree>
this week until now.
It consists of 3 parts:
1. a patch
2. a perl script (acpolish)
plural).
configure scripts etc.
added by acpolish.
To apply this:
./rtems-polish.sh
Later:
cvs add contrib
cvs add contrib/acpolish
cvs commit
subdirectory Makefiles.
used.
individual Makefile.
problem (reported by Eric)
be resolved.
or posix initialization threads
like signal dispatching.
