* tm27/Makefile.am: include leaf.am instead of leaf.cfg.
* tm26/Makefile.am: include leaf.am instead of leaf.cfg.
* tm24/Makefile.am: include leaf.am instead of leaf.cfg.
* tm16/Makefile.am: include leaf.am instead of leaf.cfg.
* tm18/Makefile.am: include leaf.am instead of leaf.cfg.
* tm02/Makefile.am: include leaf.am instead of leaf.cfg.
* tm10/Makefile.am: include leaf.am instead of leaf.cfg.
* tm11/Makefile.am: include leaf.am instead of leaf.cfg.
* tm15/Makefile.am: include leaf.am instead of leaf.cfg.
* tm19/Makefile.am: include leaf.am instead of leaf.cfg.
* tm04/Makefile.am: include leaf.am instead of leaf.cfg.
* tm17/Makefile.am: include leaf.am instead of leaf.cfg.
* tm28/Makefile.am: include leaf.am instead of leaf.cfg.
* tmck/Makefile.am: include leaf.am instead of leaf.cfg.
* tm08/Makefile.am: include leaf.am instead of leaf.cfg.
* tm12/Makefile.am: include leaf.am instead of leaf.cfg.
* tm03/Makefile.am: include leaf.am instead of leaf.cfg.
* tm13/Makefile.am: include leaf.am instead of leaf.cfg.
* tm29/Makefile.am: include leaf.am instead of leaf.cfg.
* tmoverhd/Makefile.am: include leaf.am instead of leaf.cfg.
* tm20/Makefile.am: include leaf.am instead of leaf.cfg.
* tm09/Makefile.am: include leaf.am instead of leaf.cfg.
* tm01/Makefile.am: include leaf.am instead of leaf.cfg.
* tm21/Makefile.am: include leaf.am instead of leaf.cfg.
* tm07/Makefile.am: include leaf.am instead of leaf.cfg.
* tm25/Makefile.am: include leaf.am instead of leaf.cfg.
* tm22/Makefile.am: include leaf.am instead of leaf.cfg.
* tm06/Makefile.am: include leaf.am instead of leaf.cfg.
* tm05/Makefile.am: include leaf.am instead of leaf.cfg.
* tm14/Makefile.am: include leaf.am instead of leaf.cfg.
* tm23/Makefile.am: include leaf.am instead of leaf.cfg.
* tm20/Makefile.am: Remove stubdir.rel
* tm01/Makefile.am, tm02/Makefile.am, tm03/Makefile.am,
tm04/Makefile.am, tm05/Makefile.am, tm06/Makefile.am,
tm07/Makefile.am, tm08/Makefile.am, tm09/Makefile.am,
tm10/Makefile.am, tm11/Makefile.am, tm12/Makefile.am,
tm13/Makefile.am, tm14/Makefile.am, tm15/Makefile.am,
tm16/Makefile.am, tm17/Makefile.am, tm18/Makefile.am,
tm19/Makefile.am, tm20/Makefile.am, tm21/Makefile.am,
tm22/Makefile.am, tm23/Makefile.am, tm24/Makefile.am,
tm25/Makefile.am, tm26/Makefile.am, tm27/Makefile.am,
tm28/Makefile.am, tm29/Makefile.am, tmck/Makefile.am,
tmoverhd/Makefile.am: Include compile.am
too small when OPERATION_COUNT is less than 10.
Addtional major bugs:
to convert the tmtests directory from Makefile.in to Makefile.am.
<corsepiu@faw.uni-ulm.de> which turns OPERATION_COUNT into a configure
time option.
was unnecessary. The real fix was an alignment error in the
object extend memory allocation scheme.
dependencies of "Makefile".
--enable-maintainer-mode.
future.
cd <rtems-source-tree>
this week until now.
It consists of 3 parts:
1. a patch
2. a perl script (acpolish)
plural).
configure scripts etc.
added by acpolish.
To apply this:
./rtems-polish.sh
Later:
cvs add contrib
cvs add contrib/acpolish
cvs commit
subdirectory Makefiles.
used.
individual Makefile.
problem (reported by Eric)
be resolved.
or posix initialization threads
like signal dispatching.
