* tm01/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tm02/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tm03/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tm04/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tm05/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tm06/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tm07/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tm08/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tm09/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tm10/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tm11/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tm12/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tm13/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tm14/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tm15/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tm16/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tm17/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tm18/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tm19/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tm20/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tm21/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tm22/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tm23/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tm24/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tm25/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tm26/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tm27/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tm28/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tm29/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tmck/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tmoverhd/Makefile.am: Remove AUTOMAKE_OPTIONS.
This fix is response to test results reported by Jerry Needell
<jerry.needell@unh.edu> for the SPARC/ERC32 and tracked as PR80.
* tm27/task1.c: Account for overhead in starting and stopping
the timer.
* configure.in: Remove.
* tmtests.am: Use TMPINSTALL_FILES = to make automake-1.5 happy.
* tm27/Makefile.am: include leaf.am instead of leaf.cfg.
* tm26/Makefile.am: include leaf.am instead of leaf.cfg.
* tm24/Makefile.am: include leaf.am instead of leaf.cfg.
* tm16/Makefile.am: include leaf.am instead of leaf.cfg.
* tm18/Makefile.am: include leaf.am instead of leaf.cfg.
* tm02/Makefile.am: include leaf.am instead of leaf.cfg.
* tm10/Makefile.am: include leaf.am instead of leaf.cfg.
* tm11/Makefile.am: include leaf.am instead of leaf.cfg.
* tm15/Makefile.am: include leaf.am instead of leaf.cfg.
* tm19/Makefile.am: include leaf.am instead of leaf.cfg.
* tm04/Makefile.am: include leaf.am instead of leaf.cfg.
* tm17/Makefile.am: include leaf.am instead of leaf.cfg.
* tm28/Makefile.am: include leaf.am instead of leaf.cfg.
* tmck/Makefile.am: include leaf.am instead of leaf.cfg.
* tm08/Makefile.am: include leaf.am instead of leaf.cfg.
* tm12/Makefile.am: include leaf.am instead of leaf.cfg.
* tm03/Makefile.am: include leaf.am instead of leaf.cfg.
* tm13/Makefile.am: include leaf.am instead of leaf.cfg.
* tm29/Makefile.am: include leaf.am instead of leaf.cfg.
* tmoverhd/Makefile.am: include leaf.am instead of leaf.cfg.
* tm20/Makefile.am: include leaf.am instead of leaf.cfg.
* tm09/Makefile.am: include leaf.am instead of leaf.cfg.
* tm01/Makefile.am: include leaf.am instead of leaf.cfg.
* tm21/Makefile.am: include leaf.am instead of leaf.cfg.
* tm07/Makefile.am: include leaf.am instead of leaf.cfg.
* tm25/Makefile.am: include leaf.am instead of leaf.cfg.
* tm22/Makefile.am: include leaf.am instead of leaf.cfg.
* tm06/Makefile.am: include leaf.am instead of leaf.cfg.
* tm05/Makefile.am: include leaf.am instead of leaf.cfg.
* tm14/Makefile.am: include leaf.am instead of leaf.cfg.
* tm23/Makefile.am: include leaf.am instead of leaf.cfg.
* tm20/Makefile.am: Remove stubdir.rel
* tmtests.am: Remove DEFS.
* tm01/Makefile.am, tm02/Makefile.am, tm03/Makefile.am,
tm04/Makefile.am, tm05/Makefile.am, tm06/Makefile.am,
tm07/Makefile.am, tm08/Makefile.am, tm09/Makefile.am,
tm10/Makefile.am, tm11/Makefile.am, tm12/Makefile.am,
tm13/Makefile.am, tm14/Makefile.am, tm15/Makefile.am,
tm16/Makefile.am, tm17/Makefile.am, tm18/Makefile.am,
tm19/Makefile.am, tm20/Makefile.am, tm21/Makefile.am,
tm22/Makefile.am, tm23/Makefile.am, tm24/Makefile.am,
tm25/Makefile.am, tm26/Makefile.am, tm27/Makefile.am,
tm28/Makefile.am, tm29/Makefile.am, tmck/Makefile.am,
tmoverhd/Makefile.am: Include compile.am
