* tmitronsem01/Makefile.am: Remove AUTOMAKE_OPTIONS.
* configure.in: Remove.
* tmitrontests.am: Use TMPINSTALL_FILES = to make automake-1.5 happy.
* tmitronsem01/Makefile.am: include leaf.am instead of leaf.cfg.
* tmitrontests.am: Remove DEFS.
* tmitronsem01/Makefile.am: Include compile.am
cpuopts.h.
exec/configure.in, only.
quoting bugs in autoconf).
formating changes :)
that contains:
* Removes MKLIB
handling)
<corsepiu@faw.uni-ulm.de> which converted fiels to automake.
Addtional major bugs:
for RTEMS.
