Tracked as PR72 but related to the object id problem (PR36)
reported by Todor.Todorov@barco.com.
* include/tmacros.h: Added fatal_directive_check_status_only().
* include/tmacros.h: Attempt to print errno as further information.
by the same application.
check is performed. This is needed in some timer service routines
since they are called from multiple disable levels.
check that the _Thread_Dispatch_disable_level is set to the
proper value (0 99% of the time). This automatic check significantly
reduces the chance of mismatching disable/enable dispatch pairs
while doing internal RTEMS work.
dependencies of "Makefile".
--enable-maintainer-mode.
future.
cd <rtems-source-tree>
this week until now.
It consists of 3 parts:
1. a patch
2. a perl script (acpolish)
plural).
configure scripts etc.
added by acpolish.
To apply this:
./rtems-polish.sh
Later:
cvs add contrib
cvs add contrib/acpolish
cvs commit
subdirectory Makefiles.
used.
individual Makefile.
problem (reported by Eric)
to lib/include.
be resolved.
targopts.h file.
to avoid conflict with the standard POSIX routine pause(2).
like signal dispatching.
