warnings.
be resolved.
the application requires rtems to allocate a trap table
_Thread_Ticks_remaining_in_timeslice.
Handler could timestamp the starting and stopping of timers. Since
TOD is built on top of Watchdog, this avoided a circular dependency.
reliably produce the "insufficient memory for stack space" error if this
extension is configured.
to avoid conflict with the standard POSIX routine pause(2).
variables and renaming of others.
single enumerated set of states the set of event manager variables changed.
like signal dispatching.
correct Information block.
Added "0x" to printf of id
