future.
cd <rtems-source-tree>
this week until now.
It consists of 3 parts:
1. a patch
2. a perl script (acpolish)
plural).
configure scripts etc.
added by acpolish.
To apply this:
./rtems-polish.sh
Later:
cvs add contrib
cvs add contrib/acpolish
cvs commit
PROBLEMS
can/will be fixed.
it work.
ports.
The array is too long and needs to be shortened.
Fixed interface to cofndefs.h for initial extension set.
more accurate.
for them.
the CPU family name constants.
subdirectory Makefiles.
used.
individual Makefile.
problem (reported by Eric)
for the returned old_isr_handler was non-NULL.
a path back into the source tree. This would be better for binary
distributions as well since you now have the correct output at the
install point.
warnings.
warnings.
be resolved.
the application requires rtems to allocate a trap table
_Thread_Ticks_remaining_in_timeslice.
Handler could timestamp the starting and stopping of timers. Since
TOD is built on top of Watchdog, this avoided a circular dependency.
reliably produce the "insufficient memory for stack space" error if this
extension is configured.
