path: root/c/src/tests/sptests/spsize/init.c (follow)
* added ifdef to avoid warning for unused variable.Joel Sherrill1997-04-071-2/+6
* SPARC port passes all testsJoel Sherrill1995-10-301-1/+6
* The word "RTEMS" almost completely removed from the core.Joel Sherrill1995-09-111-5/+2
* Initial revisionJoel Sherrill1995-05-111-0/+58
