* | 2001-03-29 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-03-29 | 1 | -0/+43 |
| | | | | | | | * Per PR147 addressed problems when reseting and inserting a timer into a timer chain that did not honor time passage since the last time the timer server was scheduled and the new insertion. * sp31/sp31.scn, sp31/task1.c: Added test code to detect this case. | ||||
* | 2001-01-29 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-01-29 | 1 | -3/+71 |
| | | | | | | | | | * Fixed bug where resetting a timer that was not at the head of one of the task timer chains resulted in the Timer Server task waking up too far in the future. * Added rtems_timer_get_information() directive to support testing. * sp31/init.c, sp31/system.h, sp31/task1.c: Modified to test for above condition. | ||||
* | 2001-01-16 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-01-16 | 1 | -0/+163 |
* Added tests for task-based timers. This included the new tests sp30 and sp31. * Makefile.am, configure.ac: Modified to reflect new tests and files. * sp09/screen14.c, sp09/sp09.scn: Modified to add error checks for task-based timer services. * sp30/.cvsignore, sp30/Makefile.am, sp30/init.c, sp30/resume.c, sp30/sp30.doc, sp30/sp30.scn, sp30/system.h, sp30/task1.c, sp31/.cvsignore, sp31/Makefile.am, sp31/delay.c, sp31/init.c, sp31/prtime.c, sp31/sp31.doc, sp31/sp31.scn, sp31/system.h, sp31/task1.c: New files. |
