path: root/c/src/tests/sptests/sp25/system.h (follow)
* corrected printf specifications and added casts as necessary to eliminateJoel Sherrill1997-04-071-1/+2
| | | | warnings.
* corrected printf format to avoid warningJoel Sherrill1997-04-021-1/+1
* tests now specify whether using posix initialization threads tableJoel Sherrill1996-05-291-0/+2
| | | | or rtems initialization table in configuration table
* The word "RTEMS" almost completely removed from the core.Joel Sherrill1995-09-111-6/+29
* Support for variable length names added to Object Handler. This supportsJoel Sherrill1995-08-231-1/+1
* maximum number of messages removed and include statement cleanupJoel Sherrill1995-08-171-3/+2
* Initial revisionJoel Sherrill1995-05-111-0/+32
