* | Modified UNIX simulator port so all references to native unix | Joel Sherrill | 1995-09-27 | 1 | -1/+1 |
| | | | | | stuff is in the executive source proper in the file cpu.c. This should help avoid conflicts between RTEMS POSIX files and UNIX files. | ||||
* | Moved _Thread_Information -> _RTEMS_tasks_Information. | Joel Sherrill | 1995-08-23 | 1 | -1/+1 |
| | | | | | | | Added a table of object information control blocks. Modified _Thread_Get so it looks up a thread regardless of which thread management "entity" (manager, internal, etc) actually "owns" it. | ||||
* | Changed to reflect adding object class to id | Joel Sherrill | 1995-08-18 | 1 | -1/+1 |
| | | | | Added "0x" to printf of id | ||||
* | Initial revision | Joel Sherrill | 1995-05-11 | 1 | -0/+29 |
