path: root/c/src/tests/sptests/sp19 (follow)
* updated screenJoel Sherrill1996-06-031-20/+15
* tests now specify whether using posix initialization threads tableJoel Sherrill1996-05-291-0/+2
| | | | or rtems initialization table in configuration table
* SPARC port passes all testsJoel Sherrill1995-10-301-0/+2
* Minor bug fixes to get all targets compilable and running. TheJoel Sherrill1995-09-191-6/+6
* The word "RTEMS" almost completely removed from the core.Joel Sherrill1995-09-112-9/+30
* Support for variable length names added to Object Handler. This supportsJoel Sherrill1995-08-233-3/+3
* maximum number of messages removed and include statement cleanupJoel Sherrill1995-08-173-5/+4
* after testing go32 and cvme961Joel Sherrill1995-07-211-6/+6
* Initial revisionJoel Sherrill1995-05-119-0/+798
