path: root/c/src/tests/sptests/sp13 (follow)
* The word "RTEMS" almost completely removed from the core.Joel Sherrill1995-09-114-1042/+44
* Moved _Thread_Information -> _RTEMS_tasks_Information.Joel Sherrill1995-08-231-1/+1
| | | | | | | Added a table of object information control blocks. Modified _Thread_Get so it looks up a thread regardless of which thread management "entity" (manager, internal, etc) actually "owns" it.
* Support for variable length names added to Object Handler. This supportsJoel Sherrill1995-08-236-6/+6
* Changed to reflect adding object class to idJoel Sherrill1995-08-181-1/+1
* maximum number of messages removed and include statement cleanupJoel Sherrill1995-08-177-38/+1218
* Initial revisionJoel Sherrill1995-05-119-0/+714
