future.
cd <rtems-source-tree>
this week until now.
It consists of 3 parts:
1. a patch
2. a perl script (acpolish)
plural).
configure scripts etc.
added by acpolish.
To apply this:
./rtems-polish.sh
Later:
cvs add contrib
cvs add contrib/acpolish
cvs commit
more accurate.
subdirectory Makefiles.
used.
individual Makefile.
problem (reported by Eric)
a path back into the source tree. This would be better for binary
distributions as well since you now have the correct output at the
install point.
be resolved.
to avoid conflict with the standard POSIX routine pause(2).
like signal dispatching.
