path: root/c/src/tests/sptests/sp09 (follow)
* SPARC port passes all testsJoel Sherrill1995-10-301-1/+5
* Heap changes required some changes in this screen.Joel Sherrill1995-09-191-7/+17
* Minor bug fixes to get all targets compilable and running. TheJoel Sherrill1995-09-192-14/+14
* The word "RTEMS" almost completely removed from the core.Joel Sherrill1995-09-112-9/+116
* Added unused priority ceiling parameter to rtems_semaphore_create.Joel Sherrill1995-08-281-2/+16
| | | | | | | | | | | | | | | Rearranged code to created thread handler routines to initialize, start, restart, and "close/delete" a thread. Made internal threads their own object class. This now uses the thread support routines for starting and initializing a thread. Insured deleted tasks are freed to the Inactive pool associated with the correct Information block. Added an RTEMS API specific data area to the thread control block. Beginnings of removing the word "rtems" from the core.
* Support for variable length names added to Object Handler. This supportsJoel Sherrill1995-08-237-7/+7
* maximum number of messages removed and include statement cleanupJoel Sherrill1995-08-178-48/+66
* Fully tested on all in-house targetsJoel Sherrill1995-05-242-9/+0
* Initial revisionJoel Sherrill1995-05-1124-0/+3101
