path: root/c/src/tests/sptests/sp08/init.c (follow)
* Increased stack size so test would run in debug mode.Joel Sherrill1998-04-061-1/+1
* Minor bug fixes to get all targets compilable and running. TheJoel Sherrill1995-09-191-1/+1
* The word "RTEMS" almost completely removed from the core.Joel Sherrill1995-09-111-4/+1
* Initial revisionJoel Sherrill1995-05-111-0/+56
