path: root/c/src/tests/sptests/sp07 (follow)
* This set of changes is the build of what was required to convert toJoel Sherrill1997-04-011-0/+60
| | | | | | | | | | | | | | | | | | | | GNU autoconf. This is the first large step in allowing an RTEMS user to perform a one-tree build (per crossgcc FAQ) including RTEMS in the build process. With this change RTEMS is configured in built in the same style as the GNU tools, yet retains the basic structure of its traditional Makefiles (ala Tony Bennett). Jiri Gaisler (jgais@wd.estec.esa.nl) deserves (and received) a big thank you for doing this. There are still issues to be resolved but as of this commit, all target which can be built on a linux host have been using a modified version of the source Jiri submitted. This source was merged and most targets built in the tree before this commit. There are some issues which remain to be resolved but they are primarily related to host OS dependencies, script issues, the use of gawk for hack_specs, and the dependence on gcc snapshots. These will be resolved.
* extended Task_id and Task_name arrays to avoid indexing past end of array.Joel Sherrill1996-09-171-2/+2
* tests now specify whether using posix initialization threads tableJoel Sherrill1996-05-291-0/+2
| | | | or rtems initialization table in configuration table
* The name of the test support routine pause was changed to rtems_test_pauseJoel Sherrill1996-02-221-1/+1
| | | | to avoid conflict with the standard POSIX routine pause(2).
* removed post switch extensionJoel Sherrill1996-02-131-1/+0
* Minor bug fixes to get all targets compilable and running. TheJoel Sherrill1995-09-191-4/+4
* The word "RTEMS" almost completely removed from the core.Joel Sherrill1995-09-113-13/+63
* Support for variable length names added to Object Handler. This supportsJoel Sherrill1995-08-231-1/+1
* maximum number of messages removed and include statement cleanupJoel Sherrill1995-08-171-3/+2
* Initial revisionJoel Sherrill1995-05-1113-0/+635
