path: root/c/src/tests/sptests/sp07/init.c (follow)
* Increased stack space to let test run to completion.Joel Sherrill1998-02-201-4/+4
* removed post switch extensionJoel Sherrill1996-02-131-1/+0
* Minor bug fixes to get all targets compilable and running. TheJoel Sherrill1995-09-191-4/+4
* The word "RTEMS" almost completely removed from the core.Joel Sherrill1995-09-111-4/+2
* Initial revisionJoel Sherrill1995-05-111-0/+131
