path: root/c/src/tests/sptests/Makefile.am (follow)
* 2001-01-16 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-01-161-1/+1
| | | | | | | | | | | | | * Added tests for task-based timers. This included the new tests sp30 and sp31. * Makefile.am, configure.ac: Modified to reflect new tests and files. * sp09/screen14.c, sp09/sp09.scn: Modified to add error checks for task-based timer services. * sp30/.cvsignore, sp30/Makefile.am, sp30/init.c, sp30/resume.c, sp30/sp30.doc, sp30/sp30.scn, sp30/system.h, sp30/task1.c, sp31/.cvsignore, sp31/Makefile.am, sp31/delay.c, sp31/init.c, sp31/prtime.c, sp31/sp31.doc, sp31/sp31.scn, sp31/system.h, sp31/task1.c: New files.
* 2000-11-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-11-091-1/+1
* 2000-11-02 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-11-021-1/+1
* 2000-10-26 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-10-271-1/+1
| | | | | | * Makefile.am: ACLOCAL_AMFLAGS= -I $(RTEMS_TOPdir)/macros. Switch to GNU canonicalization. * sptests.am: Remove DEFS.
* Thread iterate not ready for submission -- removed.Joel Sherrill2000-06-141-1/+1
* Patch from John Cotton <john.cotton@nrc.ca>, Charles-Antoine GauthierJoel Sherrill2000-06-121-1/+1
| | | | | | | | | | | | | | | <charles.gauthier@iit.nrc.ca>, and Darlene A. Stewart <Darlene.Stewart@nrc.ca> to add support for a number of very significant things: + BSPs for many variations on the Motorola MBX8xx board series + Cache Manager including initial support for m68040 and PowerPC + Rework of mpc8xx libcpu code so all mpc8xx CPUs now use same code base. + Rework of eth_comm BSP to utiltize above. John reports this works on the 821 and 860
* First attempt at adding simple binary semaphore in addition to the currentJoel Sherrill1999-12-131-1/+2
| | | | | "mutex" and counting semaphore. This is at the request of Eric Norum and his EPICS porting effort.
* Converted to automake.Joel Sherrill1999-11-221-9/+3
* Added new test sp28 to test the task variable directives.Joel Sherrill1999-11-111-1/+1
* rtems_semaphore_flush test from Eric Norum <eric@cls.usask.ca>.Joel Sherrill1999-11-101-1/+1
* Added sp26 which tests the rtems_task_is_suspended directive.Joel Sherrill1999-10-251-1/+1
* Patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de> to make fix bugJoel Sherrill1999-10-041-4/+4
* New configuration files added by patch fromJoel Sherrill1999-08-101-0/+21
