BSP needs to be eliminated.
of space in the workspace.
dependencies of "Makefile".
--enable-maintainer-mode.
and RTEMS configuration.
<rdasilva@connecttel.com>.
future.
cd <rtems-source-tree>
this week until now.
It consists of 3 parts:
1. a patch
2. a perl script (acpolish)
plural).
configure scripts etc.
added by acpolish.
To apply this:
./rtems-polish.sh
Later:
cvs add contrib
cvs add contrib/acpolish
cvs commit
are:
<raguet@crf.canon.fr> to make their patches work together.
Here is a patch for KA9Q stack.
This patch contains an Ethernet Driver for Western Digital,
some fixes for the UDP and TCP protocols (for endian conversion)
and some little programs which allow the test of UDP and TCP
sockets via Ethernet.
I have tested that on an Intel machine. If someone can test it
on a big-endian machine, ...
more accurate.
the CPU family name constants.
subdirectory Makefiles.
used.
individual Makefile.
problem (reported by Eric)
exercise.
be resolved.
like signal dispatching.
