* base_mp/node1/.cvsignore: Remove.
* base_mp/node1/Makefile.am: Remove.
* base_mp/node1/base_mp.doc: Remove.
* base_mp/node1/base_mp.scn: Remove.
* base_mp/.cvsignore: Remove.
* base_mp/Makefile.am: Remove.
* base_mp/apptask.c: Remove.
* base_mp/init.c: Remove.
* base_mp/system.h: Remove.
* base_mp/node2/.cvsignore: Remove.
* base_mp/node2/Makefile.am: Remove.
* base_mp/node2/base_mp.doc: Remove.
* base_mp/node2/base_mp.scn: Remove.
* .cvsignore: Remove.
* ChangeLog: Remove.
* Makefile.am: Remove.
* README: Remove.
* configure.ac: Remove.
* sample.am: Remove.
* base_sp/.cvsignore: Remove.
* base_sp/Makefile.am: Remove.
* base_sp/apptask.c: Remove.
* base_sp/base_sp.doc: Remove.
* base_sp/base_sp.scn: Remove.
* base_sp/init.c: Remove.
* base_sp/system.h: Remove.
* cdtest/.cvsignore: Remove.
* cdtest/Makefile.am: Remove.
* cdtest/cdtest.scn: Remove.
* cdtest/init.c: Remove.
* cdtest/main.cc: Remove.
* cdtest/system.h: Remove.
* fileio/.cvsignore: Remove.
* fileio/Makefile.am: Remove.
* fileio/fileio.doc: Remove.
* fileio/init.c: Remove.
* fileio/system.h: Remove.
* hello/.cvsignore: Remove.
* hello/Makefile.am: Remove.
* hello/hello.doc: Remove.
* hello/hello.scn: Remove.
* hello/init.c: Remove.
* hello/system.h: Remove.
* loopback/.cvsignore: Remove.
* loopback/Makefile.am: Remove.
* loopback/README: Remove.
* loopback/init.c: Remove.
* loopback/loopback.scn: Remove.
* minimum/.cvsignore: Remove.
* minimum/Makefile.am: Remove.
* minimum/init.c: Remove.
* minimum/minimum.doc: Remove.
* minimum/minimum.scn: Remove.
* paranoia/.cvsignore: Remove.
* paranoia/Makefile.am: Remove.
* paranoia/init.c: Remove.
* paranoia/paranoia.c: Remove.
* paranoia/paranoia.doc: Remove.
* paranoia/system.h: Remove.
* pppd/.cvsignore: Remove.
* pppd/Makefile-user: Remove.
* pppd/Makefile.am: Remove.
* pppd/README: Remove.
* pppd/init.c: Remove.
* pppd/netconfig.h: Remove.
* pppd/ppp.conf: Remove.
* pppd/pppd.options: Remove.
* pppd/pppdapp.c: Remove.
* pppd/system.h: Remove.
* ticker/.cvsignore: Remove.
* ticker/Makefile.am: Remove.
* ticker/init.c: Remove.
* ticker/system.h: Remove.
* ticker/tasks.c: Remove.
* ticker/ticker.doc: Remove.
* ticker/ticker.scn: Remove.
* unlimited/.cvsignore: Remove.
* unlimited/Makefile.am: Remove.
* unlimited/init.c: Remove.
* unlimited/system.h: Remove.
* unlimited/test1.c: Remove.
* unlimited/test2.c: Remove.
* unlimited/test3.c: Remove.
* unlimited/unlimited.doc: Remove.
* unlimited/unlimited.scn: Remove.
Adding pppd:
* pppd/Makefile-user: New, copied over from libnetworking/pppd/example.
* pppd/README: New, copied over from libnetworking/pppd/example.
* pppd/init.c: New, copied over from libnetworking/pppd/example.
* pppd/netconfig.h: New, copied over from libnetworking/pppd/example.
* pppd/ppp.conf: New, copied over from libnetworking/pppd/example.
* pppd/pppdapp.c: New, copied over from libnetworking/pppd/example.
* pppd/system.h: New, copied over from libnetworking/pppd/example.
* pppd/pppd.options: New, copied over from libnetworking/pppd/example.
* pppd/Makefile.am: New, converted to automake from Makefile-user.
* pppd/.cvsignore: New.
* Update to stable working state. Congratulations Mike! :)
* modem_example: Directory removed.
* modem_example/16550.h, modem_example/README, modem_example/modem.c,
modem_example/modem.h, modem_example/ppp.c, modem_example/ppp.h,
modem_example/pppcompress.c: Files removed.
* pppd/example/pppd.options: New file.
* pppd/README, pppd/STATUS, pppd/cbcp.c, pppd/cbcp.h, pppd/chat.c,
pppd/pppd.h, pppd/rtemsmain.c: Updated.
