path: root/c/src/tests/samples/hello/init.c (follow)
* The word "RTEMS" almost completely removed from the core.Joel Sherrill1995-09-111-4/+1
* Support for variable length names added to Object Handler. This supportsJoel Sherrill1995-08-231-1/+1
* maximum number of messages removed and include statement cleanupJoel Sherrill1995-08-171-3/+1
* Initial revisionJoel Sherrill1995-05-111-0/+41
