path: root/c/src/tests/samples/cdtest/Makefile.in (follow)
* Removed CONFIG_DIR and PROJECT_HOME directories.Joel Sherrill1998-01-201-1/+1
* Merged very large and much appreciated patch from Chris JohnsJoel Sherrill1997-07-311-1/+1
| | | | | <cjohns@plessey.com.au>. This patch includes the ods68302 bsp, the RTEMS++ class library, and the rtems++ test.
* This set of changes is the build of what was required to convert toJoel Sherrill1997-04-011-0/+66
