path: root/c/src/tests/samples/base_sp/Makefile.am (follow)
| | | | | | | | | | | | | | | | | * configure.ac: AC_INIT(package,_RTEMS_VERSION,_RTEMS_BUGS). AM_INIT_AUTOMAKE([no-define foreign 1.6]). * base_mp/node1/Makefile.am: Remove AUTOMAKE_OPTIONS. * base_mp/Makefile.am: Remove AUTOMAKE_OPTIONS. * base_mp/node2/Makefile.am: Remove AUTOMAKE_OPTIONS. * Makefile.am: Remove AUTOMAKE_OPTIONS. * base_sp/Makefile.am: Remove AUTOMAKE_OPTIONS. * cdtest/Makefile.am: Remove AUTOMAKE_OPTIONS. * hello/Makefile.am: Remove AUTOMAKE_OPTIONS. * minimum/Makefile.am: Remove AUTOMAKE_OPTIONS. * paranoia/Makefile.am: Remove AUTOMAKE_OPTIONS. * ticker/Makefile.am: Remove AUTOMAKE_OPTIONS. * unlimited/Makefile.am: Remove AUTOMAKE_OPTIONS.
* 2001-09-19 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-09-191-1/+1
| | | | | | | | | | | | | * unlimited/Makefile.am: include leaf.am instead of leaf.cfg. * base_mp/node2/Makefile.am: include leaf.am instead of leaf.cfg. * base_mp/node1/Makefile.am: include leaf.am instead of leaf.cfg. * hello/Makefile.am: include leaf.am instead of leaf.cfg. * base_sp/Makefile.am: include leaf.am instead of leaf.cfg. * paranoia/Makefile.am: include leaf.am instead of leaf.cfg. * cdtest/Makefile.am: include leaf.am instead of leaf.cfg, use make-cxx-exe. * ticker/Makefile.am: include leaf.am instead of leaf.cfg. * minimum/Makefile.am: include leaf.am instead of leaf.cfg.
* 2000-09-04 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-09-051-0/+1
| | | | | | | * base_mp/node1/Makefile.am, base_mp/node2/Makefile.am, base_sp/Makefile.am, cdtest/Makefile.am, hello/Makefile.am, minimum/Makefile.am, paranoia/Makefile.am, ticker/Makefile.am, unlimited/Makefile.am: Include compile.am
* Patch rtems-rc-20000118-2.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-01-311-1/+0
| | | | | that contains cosmetical changes to the Makefile.ams below tests (removes old, now invalid comments from these Makefile.ams).
* Patch rtems-rc-19991117-8.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1999-11-221-1/+0
| | | | to fix some minor bugs in the conversion to automake.
* Patch rtems-rc-19991117-7.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1999-11-221-0/+43
to convert the sample tests to automake.
