this week until now.
It consists of 3 parts:
1. a patch
2. a perl script (acpolish)
plural).
configure scripts etc.
added by acpolish.
To apply this:
./rtems-polish.sh
Later:
cvs add contrib
cvs add contrib/acpolish
cvs commit
that is part of the addition of POSIX timers.
that are part of the addition of POSIX timers.
blocking protocol is used.
Updated scn files to match present expected test output.
Renamed all directories to start with psx.
problem and an English problem.
generated.
subdirectory Makefiles.
used.
individual Makefile.
problem (reported by Eric)
to lib/include.
a path back into the source tree. This would be better for binary
distributions as well since you now have the correct output at the
install point.
warnings.
be resolved.
time.
Commented out calls to pthread_cond_wait and pthread_cond_timedwait without
the mutex locked before calling.
inheritsched pthread attribute from implicit to explicit scheduling
parameters.
Instead it is an indication of a request for a small delay.
