* | Removed spaces. | Joel Sherrill | 1998-12-03 | 3 | -14/+0 |
* | Changed to account for ownership only being tracked when a priority | Joel Sherrill | 1998-12-03 | 1 | -0/+8 |
| | | | | blocking protocol is used. | ||||
* | Removed all ^M from the file. | Jennifer Averett | 1998-12-03 | 1 | -156/+156 |
* | Added psx to the front of all test names. | Jennifer Averett | 1998-12-03 | 1 | -1/+1 |
* | Removed all ^M from the scn file. | Jennifer Averett | 1998-12-03 | 1 | -1253/+1253 |
* | Cleaned up test. | Jennifer Averett | 1998-12-03 | 7 | -320/+480 |
| | | | | Updated scn files to match present expected test output. | ||||
* | Added Comment that a result is valid at 4 or 5 seconds. | Jennifer Averett | 1998-12-03 | 1 | -13/+1 |
* | Updated scn files to match present expected test output. | Jennifer Averett | 1998-12-03 | 4 | -11/+267 |
* | Renamed all directories to start with psx. | Jennifer Averett | 1998-12-03 | 4 | -4/+4 |
* | Added a posix time test. | Jennifer Averett | 1998-12-03 | 1 | -2/+2 |
| | | | | Renamed all directories to start with psx. | ||||
* | Added new tests in support of the file system infrastructure. | Joel Sherrill | 1998-11-23 | 4 | -0/+218 |
* | Added tests in support of the file system infrastructure. | Joel Sherrill | 1998-11-23 | 28 | -1/+5240 |
* | Fixed comment block at the beginning of the file for a copyright date | Joel Sherrill | 1998-06-09 | 135 | -271/+270 |
| | | | | problem and an English problem. | ||||
* | Fixed screen to match actual output. | Joel Sherrill | 1998-04-27 | 1 | -3/+2 |
* | Reset the pthread attributes structure so the proper error would be | Joel Sherrill | 1998-04-27 | 1 | -1/+5 |
| | | | | generated. | ||||
* | updated copyright to 1998 | Joel Sherrill | 1998-02-17 | 178 | -178/+178 |
* | Big patch form Ralf Corsepius described in this email: | Joel Sherrill | 1998-01-30 | 16 | -64/+32 |
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | Here is the result of my nightly work to get RTEMS_ROOT=$srcdir working with different shells and relative/absolute paths. What I did is relatively simple in principle: Instead of setting RTEMS_ROOT in configure.in and then let configure substitute @RTEMS_ROOT@ inside the Makefiles, I now let each Makefile set RTEMS_ROOT from each Makefile's @top_srcdir@ value. The difference is subtile, but with enormous side effects: - If RTEMS_ROOT is set in configure, then the same single value will be propagated to all Makefiles. This breaks using relative paths, as the relative path to the root of the source tree is used inside of all subdirectory Makefiles. - Now each Makefile.in sets RTEMS_ROOT = @top_srcdir@. top_srcdir is computed individually by configure for each single Makefile.in, hereby receiving the correct value, no matter if relative or absolute paths are used. To get this working, I needed to remove setting RTEMS_ROOT from target.cfg.in, because this overrides the value of RTEMS_ROOT from each individual Makefile. Furthermore, I removed RTEMS_CUSTOM from the Makefiles and replaced all "include $(RTEMS_CUSTOM)" directives with"include $(RTEMS_ROOT)/make/custom/$(RTEMS_BSP)". Perhaps you don't like this, but I think, to have one variable less is clearer and easier to understand than having several variables refering to the next one. I enclose a small patch to this mail, which - fixes the config.h problem (to finally clearify misunderstands) - removes assignment/subsitution of RTEMS_ROOT from configure.in - contains a workaround for the application Makefile's RTEMS_ROOT problem (reported by Eric) - removes some unused lines from the toplevel Makefile.in - removes assignment of RTEMS_ROOT from make/target.cfg.in | ||||
* | Removed CONFIG_DIR and PROJECT_HOME directories. | Joel Sherrill | 1998-01-20 | 16 | -16/+16 |
* | Modified a lot of files to take a first cut at supporting building from | Joel Sherrill | 1997-12-10 | 16 | -16/+64 |
| | | | | | any directory in the build tree. The only variable which must be set before the command "gmake" is invoked is RTEMS_BSP (e.g. RTEMS_BSP=erc32). | ||||
* | Fixed typo in the pointer to the license terms. | Joel Sherrill | 1997-10-08 | 178 | -356/+356 |
* | Removed include directory at "build" point and the link of this directory | Joel Sherrill | 1997-10-08 | 1 | -2/+2 |
| | | | | | | to lib/include. Went to using a PROJECT_INCLUDE variable. | ||||
* | headers updated to reflect new style copyright notice as part | Joel Sherrill | 1997-04-22 | 178 | -890/+890 |
* | Modified to reflect change from 255 posix priority levels to 254. | Joel Sherrill | 1997-04-18 | 3 | -6/+6 |
* | Added line to install test screens so difftest does not have to have | Joel Sherrill | 1997-04-15 | 12 | -0/+24 |
| | | | | | | a path back into the source tree. This would be better for binary distributions as well since you now have the correct output at the install point. | ||||
* | corrected printf specifications and added casts as necessary to eliminate | Joel Sherrill | 1997-04-07 | 3 | -3/+3 |
| | | | | warnings. | ||||
* | corrected printf format to avoid warning | Joel Sherrill | 1997-04-02 | 4 | -4/+4 |
* | initialized variables or removed unused variables to remove warnings | Joel Sherrill | 1997-04-02 | 3 | -4/+3 |
* | This set of changes is the build of what was required to convert to | Joel Sherrill | 1997-04-01 | 16 | -0/+842 |
| | | | | | | | | | | | | | | | | | | | | GNU autoconf. This is the first large step in allowing an RTEMS user to perform a one-tree build (per crossgcc FAQ) including RTEMS in the build process. With this change RTEMS is configured in built in the same style as the GNU tools, yet retains the basic structure of its traditional Makefiles (ala Tony Bennett). Jiri Gaisler (jgais@wd.estec.esa.nl) deserves (and received) a big thank you for doing this. There are still issues to be resolved but as of this commit, all target which can be built on a linux host have been using a modified version of the source Jiri submitted. This source was merged and most targets built in the tree before this commit. There are some issues which remain to be resolved but they are primarily related to host OS dependencies, script issues, the use of gawk for hack_specs, and the dependence on gcc snapshots. These will be resolved. | ||||
* | new files | Joel Sherrill | 1996-09-18 | 3 | -0/+205 |
* | Fixed test to match change to pthread_cond_timedwait which now takes a wall | Mark Johannes | 1996-09-12 | 1 | -26/+32 |
| | | | | | | | time. Commented out calls to pthread_cond_wait and pthread_cond_timedwait without the mutex locked before calling. | ||||
* | modified test to take into account change in default value of | Joel Sherrill | 1996-09-06 | 1 | -0/+5 |
| | | | | | inheritsched pthread attribute from implicit to explicit scheduling parameters. | ||||
* | added printf of status when not successful | Joel Sherrill | 1996-09-05 | 1 | -1/+3 |
* | nanosleep no longer consider a negative value of tv_sec to be an error. | Joel Sherrill | 1996-09-05 | 1 | -6/+7 |
| | | | | Instead it is an indication of a request for a small delay. | ||||
* | Changed all EFAULTS to EINVALs | Mark Johannes | 1996-08-23 | 1 | -14/+20 |
* | filled in screen | Mark Johannes | 1996-08-23 | 1 | -0/+11 |
* | Filled in screen | Mark Johannes | 1996-08-23 | 2 | -0/+78 |
* | Filled in the screen | Mark Johannes | 1996-08-23 | 9 | -0/+479 |
* | Added build_time statement to provide a tm for the test | Mark Johannes | 1996-08-23 | 1 | -2/+4 |
* | Changed test 5 to test 10 at bottom | Mark Johannes | 1996-08-23 | 1 | -1/+1 |
* | Commented out the EINVAL for mutex not acquired befor cond_wait call | Mark Johannes | 1996-08-22 | 1 | -4/+9 |
* | updated to support ENOTSUP | Mark Johannes | 1996-08-21 | 1 | -10/+10 |
* | Added Einval case for mutex not initialized | Mark Johannes | 1996-08-20 | 1 | -0/+10 |
* | init: added tests for pthread_kill and kill errors. | Mark Johannes | 1996-08-15 | 1 | -32/+186 |
* | changed error code | Joel Sherrill | 1996-08-15 | 1 | -2/+2 |
* | changed error for too many threads to EAGAIN | Joel Sherrill | 1996-08-15 | 1 | -2/+2 |
* | pthread_mutex_init returns EAGAIN not ENOMEM when there are too many mutexes. | Joel Sherrill | 1996-08-14 | 1 | -2/+2 |
* | added test cases for NULL being passed to pthread attribute get routines | Joel Sherrill | 1996-08-14 | 1 | -0/+20 |
* | added test case for pthread_attr_getscope being passed a NULL contentionscope | Joel Sherrill | 1996-08-14 | 1 | -0/+4 |
* | system.h: added task3 and changed condition variable config to 1 | Mark Johannes | 1996-08-14 | 1 | -1/+6 |
* | task3: added to test error case in Wait_support for lock on mutex | Mark Johannes | 1996-08-14 | 1 | -0/+46 |
