<corsepiu@faw.uni-ulm.de>:
The patch below provides
before)
rtems-rc-19991123-rc-2.diff
Attention:
to convert the psxtests directory from Makefile.in to Makefile.am.
+ Added tests for sem_open, sem_close, and sem_unlink.
+ Yellow lined sem_open, sem_close, sem_unlink,
_POSIX_Semaphore_Delete, _POSIX_Semaphore_Name_to_id,
and _POSIX_Semaphore_Create_support. Except for MP, pshared
OBJECT_REMOTE, and out of memory paths.
family of macros to produce better checks and diagnostic messages.
