path: root/c/src/tests/psxtests/psxmsgq01/init.c (follow)
* Fixed warnings.Joel Sherrill2000-01-131-14/+0
* POSIX message queues now include complete functionality includingJoel Sherrill2000-01-131-247/+1074
| | | | | | | | | | | | | | | | blocking sends when the queue is full. The SuperCore was enhanced to support blocking on send. The existing POSIX API was debugged and numerous test cases were added to psxmsgq01 by Jennifer Averett. SuperCore enhancements and resulting modifications to other APIs were done by Joel. There is one significant point of interpretation for the POSIX API. What happens to threads already blocked on a message queue when the mode of that same message queue is changed from blocking to non-blocking? We decided to unblock all waiting tasks with an EAGAIN error just as if a non-blocking version of the same operation had returned unsatisfied. This case is not discussed in the POSIX standard and other implementations may have chosen differently.
* + Added tests for open, close, unlink, and send.Jennifer Averett2000-01-051-53/+223
* + Tests added for mq_open, mq_close, and mq_unlinkJennifer Averett1999-12-231-56/+213
* Jennifer added initial test code. Conditional'ed out until she hasJoel Sherrill1999-12-021-0/+130
| | | | the opportunity to work with it.
* New test for POSIX Message Queues added.Joel Sherrill1999-11-091-0/+28
