index
4.11
4.8
4.9
5
master
RTEMS Kernel, file-systems, drivers, BSPs, samples, and testsuite.
devel@rtems.org
summary
refs
log
tree
commit
diff
stats
log msg
author
committer
range
path:
root
src
tests
psxtests
psx05
init.c
follow
Commit message (
Collapse
Author
Age
Lines
Updated copyright notice.
Joel Sherrill
1999-11-17
1
-2
+1
Removed reinitialize mutex test case to reflect earlier code change in
Joel Sherrill
1999-10-25
1
-1
+8
the executive.
Changed to account for ownership only being tracked when a priority
Joel Sherrill
1998-12-03
1
-0
+8
blocking protocol is used.
updated copyright to 1998
Joel Sherrill
1998-02-17
1
-1
+1
Fixed typo in the pointer to the license terms.
Joel Sherrill
1997-10-08
1
-2
+2
headers updated to reflect new style copyright notice as part
Joel Sherrill
1997-04-22
1
-5
+5
Modified to reflect change from 255 posix priority levels to 254.
Joel Sherrill
1997-04-18
1
-2
+2
corrected printf format to avoid warning
Joel Sherrill
1997-04-02
1
-1
+1
Added Einval case for mutex not initialized
Mark Johannes
1996-08-20
1
-0
+10
pthread_mutex_init returns EAGAIN not ENOMEM when there are too many mutexes.
Joel Sherrill
1996-08-14
1
-2
+2
added numerous error test cases.
Joel Sherrill
1996-08-12
1
-13
+154
added test cases for errors in pthread_mutexattr_getpshared
Joel Sherrill
1996-08-09
1
-1
+16
added test cases for EINVAL cases in pthread_mutexattr_destroy
Joel Sherrill
1996-08-09
1
-1
+21
added test case for pthread_mutexattr_init being passed a null pointer.
Joel Sherrill
1996-08-09
1
-0
+4
changed style of output to match other tests
Joel Sherrill
1996-08-09
1
-40
+51
Init.c: added priority ceiling task cases.
Mark Johannes
1996-08-08
1
-20
+204
added test case for timeout using pthread_mutex_timedlock
Joel Sherrill
1996-07-04
1
-0
+13
first test cases for mutex manager pass
Joel Sherrill
1996-07-04
1
-0
+171
