* psx01/Makefile.am: include leaf.am instead of leaf.cfg.
* psx11/Makefile.am: include leaf.am instead of leaf.cfg.
* psxcancel/Makefile.am: include leaf.am instead of leaf.cfg.
* psx02/Makefile.am: include leaf.am instead of leaf.cfg.
* psx13/Makefile.am: include leaf.am instead of leaf.cfg.
* psxtime/Makefile.am: include leaf.am instead of leaf.cfg.
* psxchroot01/Makefile.am: include leaf.am instead of leaf.cfg.
* psx07/Makefile.am: include leaf.am instead of leaf.cfg.
* psxmsgq01/Makefile.am: include leaf.am instead of leaf.cfg.
* psxtimer/Makefile.am: include leaf.am instead of leaf.cfg.
* psx10/Makefile.am: include leaf.am instead of leaf.cfg.
* psx08/Makefile.am: include leaf.am instead of leaf.cfg.
* psxhdrs/Makefile.am: include leaf.am instead of leaf.cfg.
* psxfile01/Makefile.am: include leaf.am instead of leaf.cfg.
* psx05/Makefile.am: include leaf.am instead of leaf.cfg.
* psx09/Makefile.am: include leaf.am instead of leaf.cfg.
* psxmount/Makefile.am: include leaf.am instead of leaf.cfg.
* psxstat/Makefile.am: include leaf.am instead of leaf.cfg.
* psx12/Makefile.am: include leaf.am instead of leaf.cfg.
* psxreaddir/Makefile.am: include leaf.am instead of leaf.cfg.
* psxsem01/Makefile.am: include leaf.am instead of leaf.cfg.
* psx03/Makefile.am: include leaf.am instead of leaf.cfg.
* psx04/Makefile.am: include leaf.am instead of leaf.cfg.
* psx06/Makefile.am: include leaf.am instead of leaf.cfg.
* psx04/init.c, psx04/psx04.scn, psx07/init.c, psx07/psx07.scn,
psxfile01/psxfile01.scn, psxmsgq01/psxmsgq01.scn,
psxreaddir/test.c, psxstat/psxstat.scn, psxstat/test.c,
psxtime/psxtime.scn, psxtimer/psxtimer.scn:
Various adjustments so test output matches screens more reliably.
psx13/Makefile.am, psxcancel/Makefile.am, psxfile01/Makefile.am,
psxhdrs/Makefile.am, psxmount/Makefile.am, psxmsgq01/Makefile.am,
psxreaddir/Makefile.am, psxsem01/Makefile.am, psxstat/Makefile.am,
psxtime/Makefile.am, psxtimer/Makefile.am: Include compile.am
psx10/Makefile.am, psx11/Makefile.am, psx11/Makefile.am,
psx12/Makefile.am, psxcancel/Makefile.am, psxmsgq01/Makefile.am,
psxsem01/Makefile.am, psxsem01/Makefile.am, psxtimer/Makefile.am:
Use AM_CPPFLAGS += instead of AM_CPPFLAGS =
to convert the psxtests directory from Makefile.in to Makefile.am.
cd <srcdir>
dependencies of "Makefile".
--enable-maintainer-mode.
future.
cd <rtems-source-tree>
this week until now.
It consists of 3 parts:
1. a patch
2. a perl script (acpolish)
plural).
configure scripts etc.
added by acpolish.
To apply this:
./rtems-polish.sh
Later:
cvs add contrib
cvs add contrib/acpolish
cvs commit
subdirectory Makefiles.
used.
individual Makefile.
problem (reported by Eric)
a path back into the source tree. This would be better for binary
distributions as well since you now have the correct output at the
install point.
be resolved.
thread which has the signal unblocked.
