subdirectory Makefiles.
used.
individual Makefile.
problem (reported by Eric)
a path back into the source tree. This would be better for binary
distributions as well since you now have the correct output at the
install point.
be resolved.
that same signal to the executing thread, sees what is pending, then unblocks
that signal so the handler can execute.
thread. nanosleep() can be interrupted and return the time remaining.
This test does a basic checkout of signals with a thread-directed signal
(pthread_kill()) used to interrupt a nanosleep().
