future.
cd <rtems-source-tree>
this week until now.
It consists of 3 parts:
1. a patch
2. a perl script (acpolish)
plural).
configure scripts etc.
added by acpolish.
To apply this:
./rtems-polish.sh
Later:
cvs add contrib
cvs add contrib/acpolish
cvs commit
subdirectory Makefiles.
used.
individual Makefile.
problem (reported by Eric)
a path back into the source tree. This would be better for binary
distributions as well since you now have the correct output at the
install point.
be resolved.
Instead it is an indication of a request for a small delay.
nanosleep (yield cpu), and numerous error cases in nanosleep
include sched.h so test can invoke scheduler routines.
changed format of some output.
sched_get_priority_max.
added test case for sched_yield.
RTEMS_DEBUG is enabled.
and sched_rr_get_interval.
are basically working. This test will be enhanced further.
should do in their place. It now compiles and links.
