path: root/c/src/tests/mptests (follow)
* Added CONFIGURE_EXTRA_TASK_STACKS definition to make memory requirementsJoel Sherrill1998-04-272-0/+4
| | | | more accurate.
* updated copyright to 1998Joel Sherrill1998-02-1781-81/+81
* Big patch form Ralf Corsepius described in this email:Joel Sherrill1998-01-3043-172/+86
* Removed CONFIG_DIR and PROJECT_HOME directories.Joel Sherrill1998-01-2043-43/+43
* Modified a lot of files to take a first cut at supporting building fromJoel Sherrill1997-12-1043-43/+172
* Fixed typo in the pointer to the license terms.Joel Sherrill1997-10-0881-162/+162
* headers updated to reflect new style copyright notice as partJoel Sherrill1997-04-2281-405/+405
* Added line to install test screens so difftest does not have to haveJoel Sherrill1997-04-1528-0/+56
| | | | | | a path back into the source tree. This would be better for binary distributions as well since you now have the correct output at the install point.
* This set of changes is the build of what was required to convert toJoel Sherrill1997-04-0143-0/+1877
| | | | | | | | | | | | | | | | | | | | GNU autoconf. This is the first large step in allowing an RTEMS user to perform a one-tree build (per crossgcc FAQ) including RTEMS in the build process. With this change RTEMS is configured in built in the same style as the GNU tools, yet retains the basic structure of its traditional Makefiles (ala Tony Bennett). Jiri Gaisler (jgais@wd.estec.esa.nl) deserves (and received) a big thank you for doing this. There are still issues to be resolved but as of this commit, all target which can be built on a linux host have been using a modified version of the source Jiri submitted. This source was merged and most targets built in the tree before this commit. There are some issues which remain to be resolved but they are primarily related to host OS dependencies, script issues, the use of gawk for hack_specs, and the dependence on gcc snapshots. These will be resolved.
* tests now specify whether using posix initialization threads tableJoel Sherrill1996-05-2914-0/+27
| | | | or rtems initialization table in configuration table
* updates from Tony BennettJoel Sherrill1996-05-232-1/+16
* changes remerged after lost in disk crash -- recovered from snapshot, ↵Joel Sherrill1995-12-202-1/+54
| | | | partially recovered working tree, etc
* changes remerged after disk crash -- history lostJoel Sherrill1995-12-191-53/+0
* Modifications from Tony Bennett accepted to tune this test a little.Joel Sherrill1995-09-194-11/+22
* Incorporated the submission from John S. GwynneJoel Sherrill1995-09-191-1/+1
| | | | | | <jsg@coulomb.eng.ohio-state.edu> of the rest of the 68000-ish support for interrupt handling and bfffo support, the two BSPs he submitted (efi68k and efi332), and SGI Irix 5.3 host support.
* Minor bug fixes to get all targets compilable and running. TheJoel Sherrill1995-09-1913-21/+21
* The word "RTEMS" almost completely removed from the core.Joel Sherrill1995-09-1128-128/+475
* Added unused priority ceiling parameter to rtems_semaphore_create.Joel Sherrill1995-08-285-0/+5
| | | | | | | | | | | | | | | Rearranged code to created thread handler routines to initialize, start, restart, and "close/delete" a thread. Made internal threads their own object class. This now uses the thread support routines for starting and initializing a thread. Insured deleted tasks are freed to the Inactive pool associated with the correct Information block. Added an RTEMS API specific data area to the thread control block. Beginnings of removing the word "rtems" from the core.
* Support for variable length names added to Object Handler. This supportsJoel Sherrill1995-08-2326-26/+26
* maximum number of messages removed and include statement cleanupJoel Sherrill1995-08-1727-69/+75
* added alignment attribute for array used as partition memory.Joel Sherrill1995-08-111-1/+1
* Ada95, gnat, go32Joel Sherrill1995-07-121-1/+1
* cpu/*types.h added and successfully compiled.Joel Sherrill1995-05-302-2/+8
| | | | IDLE task priority changed from 0 to 255 during initialization.
* Fully tested on all in-house targetsJoel Sherrill1995-05-241-2/+2
* Initial revisionJoel Sherrill1995-05-11110-0/+4972
