path: root/c/src/tests/mptests (follow)
* tests now specify whether using posix initialization threads tableJoel Sherrill1996-05-2914-0/+27
| | | | or rtems initialization table in configuration table
* updates from Tony BennettJoel Sherrill1996-05-232-1/+16
* changes remerged after lost in disk crash -- recovered from snapshot, ↵Joel Sherrill1995-12-202-1/+54
| | | | partially recovered working tree, etc
* changes remerged after disk crash -- history lostJoel Sherrill1995-12-191-53/+0
* Modifications from Tony Bennett accepted to tune this test a little.Joel Sherrill1995-09-194-11/+22
* Incorporated the submission from John S. GwynneJoel Sherrill1995-09-191-1/+1
| | | | | | <jsg@coulomb.eng.ohio-state.edu> of the rest of the 68000-ish support for interrupt handling and bfffo support, the two BSPs he submitted (efi68k and efi332), and SGI Irix 5.3 host support.
* Minor bug fixes to get all targets compilable and running. TheJoel Sherrill1995-09-1913-21/+21
* The word "RTEMS" almost completely removed from the core.Joel Sherrill1995-09-1128-128/+475
* Added unused priority ceiling parameter to rtems_semaphore_create.Joel Sherrill1995-08-285-0/+5
| | | | | | | | | | | | | | | Rearranged code to created thread handler routines to initialize, start, restart, and "close/delete" a thread. Made internal threads their own object class. This now uses the thread support routines for starting and initializing a thread. Insured deleted tasks are freed to the Inactive pool associated with the correct Information block. Added an RTEMS API specific data area to the thread control block. Beginnings of removing the word "rtems" from the core.
* Support for variable length names added to Object Handler. This supportsJoel Sherrill1995-08-2326-26/+26
* maximum number of messages removed and include statement cleanupJoel Sherrill1995-08-1727-69/+75
* added alignment attribute for array used as partition memory.Joel Sherrill1995-08-111-1/+1
* Ada95, gnat, go32Joel Sherrill1995-07-121-1/+1
* cpu/*types.h added and successfully compiled.Joel Sherrill1995-05-302-2/+8
| | | | IDLE task priority changed from 0 to 255 during initialization.
* Fully tested on all in-house targetsJoel Sherrill1995-05-241-2/+2
* Initial revisionJoel Sherrill1995-05-11110-0/+4972
