which does minor cleanup for Makefile.ams below mptests, which only
removes some bogus comments from the Makefile.ams.
patch -p1 < rtems-rc-19991203-8.diff
./bootstrap
<corsepiu@faw.uni-ulm.de> which converted fiels to automake.
Addtional major bugs:
*.cfg files.
dependencies
automake and RTEMS make rules
convention)
performs automatically.
WARNING:
Makefile.ams.
cd <srcdir>
dependencies of "Makefile".
--enable-maintainer-mode.
future.
cd <rtems-source-tree>
this week until now.
It consists of 3 parts:
1. a patch
2. a perl script (acpolish)
plural).
configure scripts etc.
added by acpolish.
To apply this:
./rtems-polish.sh
Later:
cvs add contrib
cvs add contrib/acpolish
cvs commit
more accurate.
subdirectory Makefiles.
used.
individual Makefile.
problem (reported by Eric)
a path back into the source tree. This would be better for binary
distributions as well since you now have the correct output at the
install point.
be resolved.
<jsg@coulomb.eng.ohio-state.edu> of the rest of the 68000-ish support
for interrupt handling and bfffo support, the two BSPs he submitted
(efi68k and efi332), and SGI Irix 5.3 host support.
like signal dispatching.
correct Information block.
IDLE task priority changed from 0 to 255 during initialization.
