path: root/c/src/tests/mptests/mp01/init.c (follow)
* Minor bug fixes to get all targets compilable and running. TheJoel Sherrill1995-09-191-3/+3
* The word "RTEMS" almost completely removed from the core.Joel Sherrill1995-09-111-4/+1
* Initial revisionJoel Sherrill1995-05-111-0/+99
