path: root/c/src/tests/libtests/termios/Makefile.in (follow)
* Removed CONFIG_DIR and PROJECT_HOME directories.Joel Sherrill1998-01-201-1/+1
* Added new test for termios style consoles from Eric Norum.Joel Sherrill1997-10-231-0/+62
