path: root/c/src/tests/libtests/rtmonuse (follow)
* Removed CONFIG_DIR and PROJECT_HOME directories.Joel Sherrill1998-01-201-1/+1
* Ralf Corsepius reported a number of missing CVS Id's:Joel Sherrill1998-01-163-3/+3
| | | | | | | | | | > RTEMS is under CVS control and has been since rtems 3.1.16 which was > around May 1995. So I just to add the $Id$. If you notice other files > with missing $Id$'s let me know. I try to keep w\up with it. Now that you have asked -- I'll attach a list of files lacking an RCS-Id to this mail. This list has been generated by a little sh-script I'll also enclose.
* Fixed typo in the pointer to the license terms.Joel Sherrill1997-10-084-8/+8
* headers updated to reflect new style copyright notice as partJoel Sherrill1997-04-224-20/+20
* enabled floating point and fixed confdef reference to initializationJoel Sherrill1997-04-092-2/+4
| | | | tasks table.
* new testJoel Sherrill1997-04-096-0/+384
